Hi,
I am newbie in encoding world...
I recorded a channel, and I got a .TS file.
I would like to convert it in .MKV with a very good quality, but not too long encoding.
For example, if I have one hour for my .TS video, I don't want to convert it in five hour.
Is it possible ?
And what is the best way to do this please ?
Thank you
Best quality is re-wrap it with mkvtoolnix / mkvmerge. Same quality as original , very fast. You're just changing the container
No, there will be some quality loss if you reduce the filesize - because you will be re-encoding it with lossy compression. Whether or not you can "see" the quality loss is another discussion
Also, it will take much longer to re-encode compared to just stream copying with mkvtoolnix
You might use something like handbrake, staxrip, megui , hybrid - those are some popular GUI's
Convert M2TS file into MKV without any quality loss
By rocknrolla115 in forum Video ConversionReplies: 6Last Post: 14th Apr 2020, 20:05 -
Convert MKV to identical audio and video quality for Apple TV and Xbox?
By theargonaut33 in forum Video ConversionReplies: 14Last Post: 26th Oct 2017, 14:10 -
Convert mkv to avi/or mp4 with the least quality loss?
By HOK1N in forum Video ConversionReplies: 14Last Post: 12th Aug 2016, 14:59 -
Convert bluray to MKV with good quality - settings
By Spy_br in forum Blu-ray RippingReplies: 6Last Post: 6th Aug 2014, 20:57 -
Convert dvd to MKV with good quality - Handbrake settings
By Spy_br in forum DVD RippingReplies: 1Last Post: 17th Jul 2014, 17:22
