I am using a Sony PCM-D100 audio recorder to capture good sound from a local choir when I video their concerts. It vastly outperforms my camcorder's onboard or shotgun mic.
However, the audio recorder, by default, creates a new 2 GB file after each 30-minute mark. Thus, recording an hourlong concert results in 2 files.
I simply put the WAV files from the recorder on a new audio track in Final Cut Pro, one after the other. But of course, the 30-minute breaks always seem to occur in the middle of songs - never during applause or introductions, lol.
Today, I have exported a song that uses the end of WAV file 1 and the beginning of WAV file 2 - and there is a serious pop in the middle of it, right where the two files join together.
I have checked, and there is no break on the timeline between the two files (i.e., no frame gaps), and the first file is at the very end, while the second is at the very beginning. (None of the files are omitted.) But I hear a popping sound between the files, both in FCP and in the exported video. Even in the exported video's audio track, though, there is nothing in the waveform that indicates the pop - it's weird.
Is there any way to fix this?
Jen
Hi, thanks so much for the reference.
An answer turned out to be much simpler though - I just laid the files end to end in Soundtrack instead of FCP and resaved as a new file. Bingo: no pop between the files. Why Soundtrack could do this and FCP couldn't, when they're both part of the same editing package, is beyond me! -
Just laying them end to end doesn't guarantee no popping.
Popping happens when you have a large discontinuity in the waveform, which can happen naturally with true pops, but also happens when an ending waveform ends with trending-negative samples and is butt-joined to the starting waveform which begins with trending-positive samples (or vice-versa). This automatically results in abrupt waveform discontinuity/reversal. A pop.
Use and audio editor or DAW/NLE and cross-fade your transitions.
Scott -
Competent editing apps like Audition will automatically apply a tiny crossfade between butted clips. It also helps to make sure each clip begins and ends on a zero wave crossing.
Thanks for the details. I'm guessing that Soundtrack, then, applied that automatic tiny crossfade, whereas FCP didn't/couldn't. I tried it with two more of my audio recorder's files and it worked perfectly, so that's definitely a technique to remember going forward. Thanks again.
MKVToolNix problem, audio clicking sound added to remuxed files.
By RoastedGarlic in forum Video ConversionReplies: 0Last Post: 18th Apr 2018, 07:19 -
No Audio from Potplayer unless I connect my earphones
By Damien263 in forum AudioReplies: 7Last Post: 19th Dec 2017, 21:45 -
old lite on hdd recorder stop working is it possible to connect hdd to pc
By goingape in forum DVD & Blu-ray RecordersReplies: 2Last Post: 27th Aug 2015, 20:04 -
Audio 'popping' converting from DTS to AC3
By THRobinson in forum Video ConversionReplies: 23Last Post: 13th Aug 2015, 18:36 -
How to connect Magnavox Recorder to Metrocast hd box
By jcool26 in forum DVD & Blu-ray RecordersReplies: 29Last Post: 1st Jan 2014, 19:53
