Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or try DVDFab and copy, convert or make Blu-rays and DVDs! :)
Results 1 to 16 of 16
  1. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    720x576, the usual deal, but it's only 4:3 content and the black bars are useless. What's the math on this? I don't want to just eyeball it and risk distortion if the picture is only meant to be over 704 pixels.
  2. Member DB83's Avatar
    Jul 2007
    720 * 576 pal 4:3 displays as 768*576.
    But surely black bars are normal if you display that on any screen that is wider than 4:3
  3. Resize the frame to a 4:3 ratio, then crop the black bars. That will leave you with square pixels and the correct aspect ratio.
    If it's an ITU cap crop 16 pixels off the width, resize to a 4:3 ratio, then crop any remaining black bars.
  4. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    The bars are baked in. I want to get rid of them so it displays full-height on 4:3 and 16:10 displays, and co-operates with my 4:3 menu a bit better.
    How does one tell if it's ITU? And is there not a more mathematical way of doing it, rather than just guessing?
  5. Member DB83's Avatar
    Jul 2007
    Full height ?
    That kinda tells me you have wide-screen video that was then capped to 4:3. Quite common back in the day when wide displays were rarer.
    But it might be more useful if you posted a sample.
  6. ITU caps usually have about 8 pixels of black at the left and right edges.
  7. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    Yes, full height. As in, filling the full height of the screen.
    It's a VHS tape from 1992. When it was digitised, it was for some reason digitised as a 16:9 image, so there are baked-in pillarboxes. Don't ask why, it wasn't me.
  8. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    But this has lots of pixels of black at the edges, because it's pillarboxed.
    Is that a no on there being a mathy way to work it out? Are there preferred resizers out there? It's in AviSynth at the moment, which has a lot of choices.
  9. Originally Posted by koberulz View Post
    Sometimes you can see a difference between the black pillarboxing and the ITU black at the edges (ie, they're not exactly the same intensity). In the absence of that you have to guess. Typically, anything made by capturing from analog tape is ITU. You'll never notice the 2 percent difference anyway.
    The resize/crop method given is mathematically precise. Use whatever resizing algorithm is appropriate for your material. For very sharp material I use BilinearResize(). For less sharp material I use Spline36Resize().
  10. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    I've not really used resizing at all, so I have no idea about any of them.
    How is the resize/crop mathematically precise if I'm guessing at where the picture area starts and thus how many pixels to crop? Even zoomed in with VDub the edges look kinda fuzzy.
    EDIT: Hang on, your process for ITU is crop, resize, crop, resize, right? That seems inefficient, and isn't there extra quality loss from the double-resize?
  11. Member DB83's Avatar
    Jul 2007
    As I already said, that was not un-common back in the day.
    But if you want full height from 4:3 you must crop the sides and lose detail. So what you really need to do is crop the top and bottom (4:3 back to 16:9 is often 72 pixels top and 72 pixels bottom for pal and you might also have to de-interlace)
    And is not pillar-boxing but letter-boxing.
  12. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    Why are you so determined to believe I'm wrong?
  13. Member DB83's Avatar
    Jul 2007
    Talking to me ?
    Pillar-boxing is bars on left and right. Letter-boxing is bars top and bottom.
    You already stated that you have a 16:9 video with bars from a vhs. Neither 720*576 or even 704*576 (both pal) are 4:3 and you simply can not get full-height from such picture without losing detail from left and right.
    But do not believe me since you know better.
  14. Everything I say is false koberulz's Avatar
    Oct 2006
    Australia
    I know.
    Yes, pillarboxing.
    ...what?
    Except that there isn't anything on the left or right to lose, except the pillarboxing bars.
  15. Originally Posted by koberulz View Post
    If the source is 4:3 DAR then resizing to a 4:3 frame size gives you exactly the right aspect ratio. Then, no matter how much you crop the content of what remains will have the correct aspect ratio. For example, draw a picture on a piece of paper. Then cut away some amount form the edges of the paper. No matter how much you cut away, what remains of the picture has the right aspect ratio, circles remain circles, squares remain squares, etc.
    If you want a specific frame aspect ratio just use that aspect ratio when you crop. It sounds to me like what you have is a 16:9 DAR source with a 4:3 picture pillarboxed in it. Resize to 1024x576 (1024 = 576 * 16 / 9) then crop down to a 4:3 frame size 768x576 (768 = 576 * 4 / 3).
    The general equation for aspect ratios:
    DAR = FAR * SAR
    DAR = display aspect ratio, the final shape of the picture
    FAR = frame aspect ratio, frame width:height
    SAR = sample aspect ratio, the relative spacing of pixels horizontally:vertically
    When you have rendered the picture to square pixels SAR becomes 1:1 and the equation becomes:
    DAR = FAR
  16. Member DB83's Avatar
    Jul 2007
    Ok. I probably mis-read what you wrote. Did not help the situation when you wrote 'full-height'
    So if I now read correctly you have a 16:9 image with hard-coded pillar-boxed black bars.
    Now here's the 'raw prawn'. By all means crop these away so you get a true 4:3 video. But display that correctly on a 16:9 display and the player adds soft-coded pillar-box bars due to the 4:3 DAR.
    Bottom line. Why bother ?
