Hi guys, what's the best way to transfer Hi8 tapes to PC, what type or brand of camcorder to use for the playback etc... thanks. Never even seen a Hi8 tape before, don't know anthing about it.
Use a Hi8 VCR. Has more/better electronics than most camcorders, like TBC, NR, DOC.
I would recommend using a Sony Digital8 camcorder made between the years 2000 and 2007. Connect it to your computer via FireWire (it will actively digitize the video and you will have full control over the mode of operation), and then you can use your favorite capture software to capture the video as a DV-AVI file (as close as you can get to the original). Some people say to use a capture card so as to allow full color resolution that DV would limit, but the thing is, DV's color resolution limitations are more loose than those of Hi8. In other words, transferring Hi8 to DV will not result in any color loss (the other way around would). If you want to edit out blank spots of video and control your camcorder right on screen, I would recommend Scenalyzer, which is free now.
Hope this helps!
Hi8 Digitization Help
By ssbbnw in forum Capturing and VCRReplies: 9Last Post: 25th Jan 2017, 15:28 -
hi8 and Digital Hi8 backup help needed.
By SQWIB in forum Capturing and VCRReplies: 5Last Post: 8th Jul 2016, 18:13 -
Hi8 questions
By RyfromNy in forum Newbie / General discussionsReplies: 6Last Post: 6th Feb 2016, 09:16 -
Hi8 interlacing
By Event3horizon in forum RestorationReplies: 14Last Post: 2nd Aug 2014, 01:11 -
Can Hi8 distorted tapes recorded on 8mm camcorder, play on Hi8 camcorder?
By RebeccaJB in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2014, 17:39
