    Feb 2015
    Spain
    Hello. I have noticed that in some movies the audio decreases a lot in some scenes. This happens with the MPV and MPC-HC players. However with MPC-BE and Potplayer does not happen (all configured with normalization enabled). I attach a fragment of a movie. The decrease of the audio is noticeable from the 12 second, when they start talking.
    I would like to know what is the reason for this decrease in audio and if it can be changed in MPV, which is the player that I use the most.
    Apr 2018
    Croatia
    Try:
    mpv fragmento.mkv -af dynaudnorm=f=10
    Feb 2015
    Spain
    Thank you. It works but the normalization does not work so well. Which parameters are the best for a more stable normalization?
    Apr 2018
    Croatia
    You need to explain more what "stable" normalization means.
    Feb 2015
    Spain
    In some movies I notice ups and downs in the audio. As if in some scenes the normalization (dynaudnorm) would not work as well as it should.
    Before, I had it configured like this
    af=lavfi=[loudnorm=I=-25:TP=-1.5:LRA=1]
    and the normalization worked very well except for those audio decreases that I have noticed in some movies.
  6. dynaudnorm and loudnorm are two different audio filters. Can you please be more specific?
    Feb 2015
    Spain
    With this configuration it seems that I no longer have problems
    af=lavfi=[dynaudnorm=f=75:g=25:p=0.55]
    thank you
