360p to 1080p with watchable quality
please share settings
- is 3000kbps/30fps is good for 360p to 1080p
any software with any magic![]()
No magic. Just "very very educated guessing" in software. AviSynth or VapourSynth based converters can use a variety of scaling functions which may look more or less convenient to you. And in addition, there is "Edge Directed Interpolation" (e.g. NNEDI3) with a special function that increases the resolution by powers of 2, in your case to 4 times the width and height, while trying to emphasize straight edges. The result may look a bit artifical, though, but you may prefer that over too soft or too much ringing results of conservative scaling techniques.
Main disadvantage for you: The more you try, the better you will know if there is any good result at all; but it takes more time to try more different techniques. And you may have to study and learn video scripting before you succeed. It may not be easy to find a converter which provides all the good methods without learning their backgrounds.
If you only want to play it on a PC, the easiest solution for you may be using madVR as high quality renderer, no need to actually recode the video.
How To set Primevideo's Quality Manualy To 1080p
By HiBaNA in forum Video Streaming DownloadingReplies: 0Last Post: 19th Sep 2017, 10:49 -
Best 1080p Quality Settings
By GianCist in forum Video ConversionReplies: 3Last Post: 17th Nov 2015, 15:17 -
Best Quality settings for 1080p x264
By GianCist in forum Blu-ray RippingReplies: 5Last Post: 9th Nov 2015, 07:56 -
Handbrake Question: Lower quality 1080p, or higher quality 720p?
By natebetween in forum Blu-ray RippingReplies: 78Last Post: 8th Feb 2015, 22:25 -
When will a video called 240p/360p/480p/720p/1080p
By psycholyzern in forum Newbie / General discussionsReplies: 13Last Post: 11th Nov 2013, 14:53
