  1. I need to convert some graphic text screenshots back into actual text. I originally wanted one capable of batch-processing but instead I stacked a bunch of screenshots together into one image to avoid that. They are screenshots of video metadata because some genius decided to archive video info of a whole series into JPEGs... Yeah...
    There must be some lunatic out there who lost all these episodes in a crash so I'll archive a bunch of useful info on my site and make it unsearchable JPEG to make his job that much harder. Seriously...
    Anyway, I only tried FreeOCR so far and it... sucks. 'Nuff said. Any other recommendations?
  2. Did you try to learn/train tesseract (freeocr use tesseract library).
    https://github.com/tesseract-ocr/tesseract/wiki/TrainingTesseract
    http://pretius.com/how-to-prepare-training-files-for-tesseract-ocr-and-improve-charact...s-recognition/
    Without tesseract you are probably forced to use commercial software and seem Abbyy Finereader is frequently mentioned as best.
  3. Gray-scale or black and white text is easier for an OCR.
    Abbyy Finereader and Nuance Omnipage are the best commercial.
    As for freeware you can try online OCRs which I believe use tesseract, they aren't bad.
  4. I got stuck on this part on that tutorial.
    N=662 # set accordingly to the number of files that you have
    for i in `seq 0 $N`; do
        tesseract $i.bmp $i batch.nochop makebox
    done
    gives me
    bash: seq: command not found
    I'm a little confused because the tutorial never instructs where to point the cygwin program at so it can find the image files. Like, how would it know where to look without specific input from me? The article never mentions this. It just tells me to name them a certain way and run that script in cygwin.
  5. Originally Posted by Aludin View Post
    snip
    Can't help and i'm affraid that you may not find help on this forum either - on your side i would search for help on tesseract forum - perhaps only one way to you will be train tesseract in Linux environment (i assume you trying to do this in Windows environment).
