Hello everyone,
I've recently downloaded a music video from YouTube but it's affected by very big compression artifacts (such as blocks).
So far I've tried a couple of solutions but none of them seemed to work fine; can anybody help me please?
To reach my goal I'm not interested in losing a little detail on the footage, but I'd like to get rid of almost every block artifact.
Thanks a lot. (Sample attached: check for example the close-up shot at 6 seconds mark).
Can't be done,that's from too low of a bitrate setting.
You can definitely clean it up a bit but it may be difficult with the contrast.
I was able to get decent results with just TemporalDegrain2 in Avisynth. On your source I had usedIf you are the uploader of the video or know the uploader, you could potentially download the source file before YT compression by using Google Takeout, if that's still possible. The files generated with Takeout are different from the ones you can download through YT's Video Manager. Most of the time, depending on upload date, they will be the original source file that was uploaded, untouched.Code:TemporalDegrain2(degrainTR=1,postFFT=3,extraSharp=true)
Here's a before and after of TD2 that I had used. I don't know too much about the sharpening filters but using one could enhance the edges and make it better than the source.
What music video is it ?
Did you look for a higher quality version ? e.g. sometimes the YT VP9 version has higher quality, but sometimes only in some sections
Or vevo ? They usually have higher bitrates but with duplicates that you can decimate -
Need help with strong halos, color bleed (EP16, Neon Genesis Evangelion)
By pwnsweet in forum EditingReplies: 13Last Post: 21st May 2022, 01:41 -
Wi-Fi internet keeps dropping out despite strong signal
By Sakuya in forum ComputerReplies: 9Last Post: 11th Dec 2017, 01:27 -
Choppy playback - MPC-HC - STRONG Hardware
By Retrogue in forum Software PlayingReplies: 4Last Post: 23rd Sep 2017, 06:05 -
Dealing with strong deblocking
By Marcoh_ in forum RestorationReplies: 17Last Post: 22nd Apr 2017, 21:48 -
Need help with a strong backlight on my video clip
By MartinMtb92 in forum EditingReplies: 47Last Post: 11th May 2015, 14:54
