Closed Thread
  1. TL;DR - My GTX 1050Ti is failing when trying to encode 4K to 4K burning in subs.
    Edit Bonus: Anyone that can help me solve this problem I will gladly show you a very simple way to download movies from a shared plex server that is not yours, without the owners permission.
    A little background....
    I use Plex to watch all my video content including 4K. I don't transcode anything! Only Direct Play on both Video and Audio.
    I find that subtitles can cause transcoding within Plex so I prefer to burn in subs for a movies that have foreign language parts. I have used many programs to do this the the past including StaxRip and Handbrake but I prefer Pavtube. It seems to be the simplest and does well with hardware acceleration. I'm happy with the results I get.
    I'm running into an issue with 4K movies. Pavtube and StaxRip both fail at the beginning of conversion. I'm not able to get the Pavtube logs but I have included the StaxRip logs at the end of this post. I prefer StaxRip for this job because I believe it is one of the only programs that can retain HDR color space in the process.
    I'm at my wits end and I cant figure out whats wrong.
    Things i've tried:
    All Nvidia drivers are up to date.
    Nvidia GForce and Nvidia control panel are up to date.
    All system drivers are up to date.
    OS is up to date.
    StaxRip x64 2.0.0 all up to date
    Hardware specs:
    i5-2400S 2.5GHz (Sandy Bridge) CPU
    Intel DH67CL Motherboard
    DDR3-1600 8Gx4 = 32GB Ram
    MSI GTX 1050Ti GPU
    EVGA 6000W PSU
    256GB SSD M.2 with SATA III 6GBs adapter (only for OS and encoding software)
    Windows 10 Pro OS
    I think it looks cool! https://imgur.com/gallery/jsec83h
    I only use this for Plex and video encoding, no gaming.
    Does anyone have any ideas? Are there any test programs I can use to test NVENC on the GPU?
    Thank You in advance!
    StaxRip Logs:
    -------------------------- System Environment --------------------------
    StaxRip : 2.0.0.0
    Windows : Windows 10 Pro 1803
    Language : English (United States)
    CPU : Intel(R) Core(TM) i5-2400S CPU @ 2.50GHz
    GPU : NVIDIA GeForce GTX 1050 Ti
    Memory : 3 GB
    Resolution : 1920 x 1080
    DPI : 144
    ------------------------ MediaInfo Source File ------------------------
    F:\The.Martian.2015.Extended.Cut.PROPER.UHD.BluRay .2160p.TrueHD.Atmos.7.1.HEVC.REMUX-FraMeSToR.mkv
    General
    Complete name : F:\The.Martian.2015.Extended.Cut.PROPER.UHD.BluRay .2160p.TrueHD.Atmos.7.1.HEVC.REMUX-FraMeSToR.mkv
    Format : Matroska
    Format version : Version 4 / Version 2
    File size : 37.3 GiB
    Duration : 2 h 31 min
    Overall bit rate : 35.3 Mb/s
    Encoded date : UTC 2018-11-03 18:16:02
    Writing application : mkvmerge v28.1.0 ('Morning Child') 64-bit
    Writing library : libebml v1.3.6 + libmatroska v1.4.9
    Video
    Format : HEVC
    Format/Info : High Efficiency Video Coding
    Commercial name : HDR10
    Format profile : Main 10@L5.1@High
    Codec ID : V_MPEGH/ISO/HEVC
    Bit rate : 34.7 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 23.976 (23976/1000) FPS
    Original frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0 (Type 2)
    Bit depth : 10 bits
    Bits/(Pixel*Frame) : 0.174
    Stream size : 36.6 GiB (98%)
    Writing library : ATEME Titan KFE 3.7.3 (4.7.3.1003)
    Default : Yes
    Forced : No
    Color range : Limited
    Color primaries : BT.2020
    Transfer characteristics : PQ
    Matrix coefficients : BT.2020 non-constant
    Mastering display color primaries : Display P3
    Mastering display luminance : min: 0.0000 cd/m2, max: 1000 cd/m2
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : A_AC3
    Bit rate mode : Constant
    Bit rate : 640 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -1 ms
    Stream size : 693 MiB (2%)
    Title : AC3 5.1
    Language : English
    Service kind : Complete Main
    Default : No
    Forced : No
    ----------------- Demux MKV using mkvextract 28.2.0.7 -----------------
    "C:\Users\Nicholas\Desktop\Video Editing Tools\StaxRip-x64-2.0.0.0\Apps\MKVToolNix\mkvextract.exe" F:\The.Martian.2015.Extended.Cut.PROPER.UHD.BluRay .2160p.TrueHD.Atmos.7.1.HEVC.REMUX-FraMeSToR.mkv tracks 1:"F:\The.Martian.2015.Exte..._temp\The.Martian.20 15.Extended.Cut.PROPER.UHD.BluRay.2160p.TrueHD.Atm os.7.1.HEVC.REMUX-FraMeSToR ID1 -1ms English AC3 5.1.ac3" --ui-language en
    Extracting track 1 with the CodecID 'A_AC3' to the file 'F:\The.Martian.2015.Exte..._temp\The.Martian.2015 .Extended.Cut.PROPER.UHD.BluRay.2160p.TrueHD.Atmos .7.1.HEVC.REMUX-FraMeSToR ID1 -1ms English AC3 5.1.ac3'. Container format: Dolby Digital (AC-3)
    Start: 9:32:58 AM
    End: 9:38:10 AM
    Duration: 00:05:11
    General
    Complete name : F:\The.Martian.2015.Exte..._temp\The.Martian.2015. Extended.Cut.PROPER.UHD.BluRay.2160p.TrueHD.Atmos. 7.1.HEVC.REMUX-FraMeSToR ID1 -1ms English AC3 5.1.ac3
    Format : AC-3
    File size : 693 MiB
    Overall bit rate mode : Constant
    Overall bit rate : 640 kb/s
    Audio
    Format : AC-3
    Bit rate : 640 kb/s
    Bit depth : 16 bits
    Stream size : 693 MiB (100%)
    --------------------------- AviSynth Script ---------------------------
    LoadCPlugin("C:\Users\Nicholas\Desktop\Video Editing Tools\StaxRip-x64-2.0.0.0\Apps\Plugins\both\ffms2\ffms2.dll")
    LoadPlugin("C:\Users\Nicholas\Desktop\Video Editing Tools\StaxRip-x64-2.0.0.0\Apps\Plugins\both\VSFilterMod\VSFilterMod. dll")
    FFVideoSource("F:\The.Martian.2015.Extended.Cut.PR OPER.UHD.BluRay.2160p.TrueHD.Atmos.7.1.HEVC.REMUX-FraMeSToR.mkv", colorspace = "YV12", \
    cachefile = "F:\The.Martian.2015.Exte..._temp\The.Martian.2015 .Extended.Cut.PROPER.UHD.BluRay.2160p.TrueHD.Atmos .7.1.HEVC.REMUX-FraMeSToR.ffindex")
    TextSubMod("F:\Downloads\The.Martian.2015.Extended .Cut.PROPER.UHD.BluRay.2160p.TrueHD.Atmos.7.1.HEVC .REMUX-FraMeSToR.srt")
    Histogram("levels", Bits=10)
    -------------------------- Script Properties --------------------------
    Source Frame Count : 217718
    Source Frame Rate : 23.976024
    Source Duration : 02:31:20.6550000
    Target Frame Count : 217718
    Target Frame Rate : 23.976024
    Target Duration : 02:31:20.6550000
    ----------------------- MediaInfo Audio Source 1 -----------------------
    General
    Format : AC-3
    File size : 693 MiB
    Audio
    Format : AC-3
    Bit rate : 640 kb/s
    Bit depth : 16 bits
    ---------------- Error Video encoding using NVEnc 4.20 ----------------
    Video encoding using NVEnc 4.20 failed with exit code: 1 (0x1)
    The exit code might be a system error code: STATUS_WAIT_1
    The exit code might be a system error code: Incorrect function.
    ------------------- Video encoding using NVEnc 4.20 -------------------
    "C:\Users\Nicholas\Desktop\Video Editing Tools\StaxRip-x64-2.0.0.0\Apps\NVEnc\NVEncC64.exe" --vbrhq 3200 --codec h265 --preset quality --level 4.1 --output-depth 10 --weightp --lookahead 32 --aq --colormatrix bt2020nc --colorprim bt2020 --transfer smpte2084 --vpp-deband -i F:\The.Martian.2015.Exte..._temp\The.Martian.2015. Extended.Cut.PROPER.UHD.BluRay.2160p.TrueHD.Atmos. 7.1.HEVC.REMUX-FraMeSToR.avs -o F:\The.Martian.2015.Exte..._temp\The.Martian.2015. Extended.Cut.PROPER.UHD.BluRay.2160p.TrueHD.Atmos. 7.1.HEVC.REMUX-FraMeSToR_out.h265
    HEVC encode with weightp is known to be unstable on some environments.
    Consider not using weightp with HEVC encode if unstable.
    Failed to Initialize the encoder
    .: 8 (NVENC indicates that one or more of the parameter passed to the API call is invalid.)
    Start: 9:40:18 AM
    End: 9:40:25 AM
    Duration: 00:00:06
    Edit: I used the follow guide for StaxRip settings.
    https://www.youtube.com/watch?v=WVMVuG1fEWY
  2. Tl;dr
  3. I'm a Super Moderator johns0's Avatar
    canada
    Nitobert-Please do not ask for help on illegally downloaded movies,this is against forum rules,this thread is closed.
