Hi,
I would like to ask how to join quickly video files together. I don't understand a lot in video editing so I'm looking for some qualified help. The task usually looks like this:
33 video files (each around 600Mb large) in .mp4 format each 15 minutes long (1270 x 720)
we cut the beginning and end to make an 8-hour video
the output file should have the same resolution and we don't care much about the video quality as long as you can tell what's in the video
we now use adobe premiere for this operation and it is set on H.264, VBR 1 pass Target 0,4 Mbps and Max 1,5 Mbps with no Audio
now this operation takes about 1,5 hour
the question is if there is a way to do this operation faster by any parameter settings or what shall I set so that the operation takes less time...
we used to use Ultra Video Joiner which takes 18 minutes on the same computer to merge 17 files into 4-hour .avi, but this software doesn't support queuing
Thanks a lot for your help...![]()
Results 1 to 1 of 1
How to change fast forward video format to standard speed video with voice
By Shah82 in forum RestorationReplies: 2Last Post: 11th Jan 2018, 11:04 -
how to join video trailers and write in each video name & # of the movie
By kathirie in forum Newbie / General discussionsReplies: 0Last Post: 24th Dec 2017, 13:01 -
[SOLVED] Fast and good tool to join MPEG files?
By yetanotherlogin in forum EditingReplies: 11Last Post: 31st Jan 2015, 21:08 -
how to join video files pls ?
By erzane in forum Newbie / General discussionsReplies: 30Last Post: 16th Sep 2014, 15:01 -
Is my pc fast enough for this madvr settings and are this the best setting
By stardust018 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2014, 08:03
