Trying a very simply fanedit, but every time I render the movie, some clips stutter while others don't.
What's causing the problem here? Is it frame rate?
My process is to use MakeMKV to rip the BluRay. To get Vegas to read the video track, I use Avidemux to produce an AVC file, formatted for PSP.
I recently noticed the file output (using the preset for PSP) results in a 100 fps file. I don't understand enough to not use the preset, so, I'm flying blind here.
I'm rendering using Sony's AVC format, with the 23.97 fps setting.
Or is the problem not frame rate?
I've been experimenting with moving my cut points just a frame or two in each direction, but I can't see a pattern of it effecting which clips stutter and which don't. Clips that I don't touch end up effected upon subsequent renders, sometimes.
Does this sound familiar to anyone?
Results 1 to 11 of 11
The normal way is to decompress to Mpeg2. Vegas is optimized for Mpeg2. You can even do Smart Rendering. Of course once you finish editing in Mpeg2 then you can render to higher compression format like mp4 or whatever.
Thanks so much for this. I didn't know that.
Any advice as to which software to use, to encode to Mpeg2? -
Let Vegas transcode it. Set project to Mpeg2 before import and it will do automatically. Vegas Pro can do everything within the software. No need to use utility programs normally.
Wait, what PDR said down below is the holy grail if you can get it. See Post #6 below.Last edited by budwzr; 10th Nov 2018 at 20:04.
If it's an AVC or MPEG2 blu-ray , you can use tsmuxer to put it into a transport stream and import it directly into vegas. No quality loss, much faster . The problem is vegas does not support mkv container . There are VC-1 blu-rays (less common), those will not be supported natively by vegas . You can use mediainfo on the mkv to determine what it is.
I'm growing more and more confident the problem is copy protection.
Although MakeMKV produces a file I can play on my PC (using VLC, MPC, etc.), I believe Vegas is detecting somehow that this was a copy-protected file, and thus rejecting the video stream coming from MakeMKV.
I've learned that finding a way to re-encode it (as I've been doing with Avidemux) solves the problem, however the challenge lay with re-encoding it in a manner that doesn't completely mess with the FPS. Using the PSP preset in Avidemux, Vegas now accepts the video file, but it's at this crazy 100fps, which I believe is contributing to my stutter problem upon editing/rendering. -
Try "Match Media" Settings in "New Project Properties" dialog box too. Match Media sets the whole project to your source media. No, Vegas doesn't support MKV, so use Mp4 as final output.
You've already been advised that Vegas doesn't accept MKV input. It has nothing to do with copy protection. pdr has already suggested using TSMuxer on it before then opening it in Vegas. Reencoding it just degrades the video before you even begin work on it. Not a good idea.
The OP said it's just a FanEdit of a video game.
P.S. With all due respects.Last edited by budwzr; 10th Nov 2018 at 12:59.
I personally can’t load MKV files into Vegas so I convert them to .mp4 using Any Video Convertor. Maybe try converting the file to .mp4? If it’s only messing up after you render the video it might be as simple as changing something in Vegas’s setting.
Stutter playing 50fps on TV
By akkers in forum Video ConversionReplies: 47Last Post: 12th Mar 2018, 10:00 -
Stutter effect?
By naalarcon in forum EditingReplies: 1Last Post: 7th Oct 2016, 18:32 -
is there a way to get rid of this Stutter?
By zanzar in forum Newbie / General discussionsReplies: 4Last Post: 25th May 2016, 18:30 -
What settings to use to render videos which are the combination of clips fr
By avz10 in forum Video ConversionReplies: 9Last Post: 11th Aug 2015, 21:07 -
Audio Stutter
By Mr_Flintstone in forum Video ConversionReplies: 0Last Post: 25th Apr 2014, 19:21
