Hi,
I have an mp4 file and 2 subtitles (English and Japanese). Resolution is 1920 x 1080 (video: AVC, audio: AAC LC, subtitles: PGS/PGS).
I combined them all together into an mkv file using MkvToolNIX (64-bit) 28.2.0.
Then I used tsMuxer 2.6.12 to create AVCHD folder, and then I used ImgBurn to burn it into DVD.
I found that my Sony BDP-S360 is unable to play it.
The steps above had been tweaked and finalized based on what I found in the forum.
What did I miss?
Please find below is the complete info on the AVCHD folder from:
Duration: 1 h 2 min
1 video stream: AVC
1 audio stream AAC/LC
2 text streams: PGS/PGS
Video: 1920*1080 (16:9). at 23.976 (24000/1001) FPS, AVC (High@L4)(CABAC / 3 Ref Frames)
Audio: 44.1 kHz, 2 channels, AAC LC (ADTS)(Version 2).
Thanks in advance.
Results 1 to 16 of 16
the subs may have to be in .srt format is all i can guess. if the sony plays other .mkv files see what's in them.
Try putting the folder(name it AVCHD) on to a thumb drive and see if it plays on the 360,if it don't then somethings wrong with the video.
AAC audio is incompatible with "AVCHD" discs or any derivative . You can try converting to AC3 .
What is the video bitrate ? DVD media is limited to lower bitrates than BD media . <15Mb/s is safe, but some players might be able to get away with 24Mb/s -
you could try using multiAVCHD it was ok back when avchd was a format being used. i still think pgs subs aren't allowed and pdr is correct aac also isn't allowed and i don't think multiavchd could use them as input either.
Yes, the original files are in srt. I run MediaInfo on the AVCHD folder.
Could it be that when MkvToolNIX combined them into mkv it changed the format to PGS? -
The original files are in srt. Perhaps MkvToolNIX converted them to PGS when I combined it with the video file.
Sounds like I need to split the audio and video, convert the audio to ac3, use original srt files, and combined them back all together (with multiAVCHD I assume?).
Is that right? -
Good news!!
I used multiAVCHD, I worked on original mp4 file and the 2 srt, multiAVCHD automatically encode the audio to ac3, and then I selected "AVCHD (strict)" mode, and voilaaa!!
Thanks a lot everybody!
I see. Sorry, my bad, perhaps tsMuxer did that.
Anyway, it's the final form in AVCHD folder, and I think it's correct, right?
If I remember correctly, when I run MediaInfo on the AVCHD folder (strict) from multiAVCHD, I saw it's in PGS format as well. -
seems this player has issues playing AVCHD files - http://www.expertreviews.co.uk/tvs-entertainment/blu-ray-players/49084/sony-bdp-s360-review
I just read the review and found that the Sony BDP-S360 isn't a very good player at all,my Sony BDP-S380 will play any mp4/mkv as long as its 4.1 profile or less in authored or data form on usb.
Thanks for confirming it.
I need to use "AVCHD (strict)" option in multiAVCHD, which is intended for Panasonic based on what multiAVCHD told me. -
Hi John,
I agree. It's an old BD Player (9 years old) I got from a door prize. Should I need a new one in the near future I'll make sure I'll do a thorough research.
Btw, if you choose "AVCHD (strict)" output in multiAVCHD (which was intended for Panasonic player), this player supports it.
No BDMV exists in AVCHD folder
By CM120884 in forum Video ConversionReplies: 1Last Post: 16th May 2018, 17:32 -
Burning a VIDEO_TS folder to disc makes it a playable DVD right ?
By Bansaw in forum Authoring (DVD)Replies: 25Last Post: 1st Mar 2015, 15:34 -
Problem with playing .mts (avchd) videos
By kmb5 in forum Newbie / General discussionsReplies: 9Last Post: 11th Jul 2014, 18:32 -
transfering AVCHD video to dvd-rw disc
By postie1392 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 28th Jun 2014, 08:33 -
Strange problem when playing a muxed AVCHD BD on the Oppo; no picture!
By naiera in forum Authoring (Blu-ray)Replies: 63Last Post: 11th Jun 2014, 13:33
