Hi all,
I have I Sony DCR-TRV12E/TRV14E camcorder. I would like to capture my DV movies on my PC. My computer does not have a Firewire connection.
Which solution is the best:
- using a capture device and hooking that up to your pc
- connecting the camcorder directly to your pc using usb
Any thoughts?
Some devices are better than others but it's not the interface that makes the difference. But firewire capture is better than both because it's basically a file transfer -- the digital data on the tape is copied to the computer and put in a file. You end up with an exact copy of what's on the tape. Using an analog capture device incurs several losses of quality, converting digital to analog, transmission noise in the cables/connetors, then converting the analog video back to video.
Ok, thank you. So no capture device. What is the best way to do it without a firewire connection? For now, I only see one solution: buying a PCI-card. Am i correct?
Yes, you need a PCI or PCIe card, whatever is appropriate for your computer. Look for one with a Texas Instruments chip. Some of the others don't work for video.
Firewire to USB interface between cam and pc ?
or add a Firewire PCI card into your pc, that would be better than USB.
https://www.amazon.com/Ports-Firewire-IEEE1394-Controller-firewire/dp/B00312MXRM/ref=p...09D51DF4DPBJAXLast edited by Eric-jan; 23rd Nov 2018 at 10:48.
chinese usb 3 device capture
By codebox in forum Capturing and VCRReplies: 28Last Post: 21st Jul 2021, 15:20 -
Out of touch with video capture - USB capture device advice
By Lambchop in forum Capturing and VCRReplies: 7Last Post: 25th Nov 2018, 04:19 -
Magewell USB to HDMI Capture Device HELP
By bdizzle009 in forum Capturing and VCRReplies: 2Last Post: 6th Feb 2017, 06:21 -
cheap usb capture device from ebay
By dleboone in forum Capturing and VCRReplies: 10Last Post: 1st Nov 2015, 09:50 -
USB 3 Analog to Digital Capture Device?
By rayjVideo in forum Capturing and VCRReplies: 3Last Post: 29th Jan 2014, 15:39
