Hi,
I have two issues when converting SRT to SUP using tsMuxeR.
After conversion I have to remux using MKVToolnix with -4200000ms offset to align subtitles with video/audio tracks. The tsMuxeR GUI only allows offset of -420000, so the solution is to use command line with -4200000 which works fine. This is a workaround I can live with but prefer the GUI to work properly
- After conversion I have to remux using MKVToolnix with -4200000ms offset to align subtitles with video/audio tracks. The tsMuxeR GUI only allows offset of -420000, so the solution is to use command line with -4200000 which works fine. This is a workaround I can live with but prefer the GUI to work properly
- The main problem is that as soon as tsMuxeR encounters a line in the SRT which is italics, all subtitles following this are set to italics for the rest of the movie. Is there a workaround to this?
I have tested with tsMuxeR 2.6.11 (Linux) and 2.6.12 (Windows) with same results.
tsMuxeR options used:
Is there any other software that can convert SRT to SUP successfully?Code:MUXOPT --no-pcr-on-video-pid --new-audio-pes --vbr --vbv-len=500 S_TEXT/UTF8, "/media/WIP/TEST/a.srt",font-name="Arial",font-size=72,font-color=0xffe1e1e1,bottom-offset=24,font-border=5,text-align=center,video-width=1920,video-height=1080,fps=23.976, lang=eng
Thanks for any help, Mark
SRT to MicroDVD (.sub) conversion out of sync.
By sandrock92 in forum SubtitleReplies: 1Last Post: 22nd Oct 2018, 11:18 -
Problem with tsmuxer
By DRC22 in forum Authoring (Blu-ray)Replies: 0Last Post: 15th Sep 2016, 04:09 -
"Invalid SRT format. "06B20BF0" is invalid timing info" error with tsMuxeR
By Jijital in forum Authoring (Blu-ray)Replies: 6Last Post: 3rd Feb 2016, 00:18 -
How to add srt to mp4 without video conversion with handbrake?
By hibbs in forum SubtitleReplies: 4Last Post: 18th Jun 2015, 22:49 -
Synchronization problem with TsMuxer
By mapomme1108 in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Jan 2015, 10:20
