Hi,
I've several avi's and mp4 files that I want to convert to a specific size, codec etc.
Can I extract the data from an Avi and replicate everything from it to encode codec, size, frame rate etc to convert my non compatible avi's and mp4s?
If so how do I do it and which software do I need?
Chris
What are your restrictions exactly ? Should the converted files be read by a standalone player of some kind ? If not, what should they be compatible with ?
With MediaInfo you can quickly identify the parameters of a known working file, and then use those parameters in a good conversion software (often recommanded here are : Avidemux, MeGUI, StaxRip, XMediaRecode, Hybrid, Handbrake, AutoGK, VirtualDub, WinFF...). Or if it's a well-known standalone player, you could consult its documentation to see what formats and parameters it can read, run some tests until you find something satisfying. Be aware though that transcoding files which are already in a lossy format will result in a further quality loss, so you should keep the native AVI/MP4 for archiving if they're worth keeping (and if they're not keeping, one has to wonder if they're worth viewing at all, in this day and age where more content is created every single day than you could possibly absorb and assimilate in a lifetime). It would be less time-consuming to update the player's firmware if possible, or switch to a more recent player if not.
To get more specific insights you'll need to provide more specific input... -
Hi,
Basically I've a Jamma board with video previews. I've managed to source the video previews from the internet.
I've got one file that I know works with the Jamma so I need to replicate that file in codec, resolution etc to get all of the other video previews to work.
I think the software is Linux based but that's all I know. I just thought I could extract the details of the working file and reencode the others so that they are the same.
ThanksLast edited by chrisino; 3rd Nov 2018 at 16:27.
Hi. Here's the settings I want to replicate.
Thanks.
General
Complete name : E:\Example.avi
Format : AVI
File size : 2.14 MiB
Duration : 16 s 350 ms
Overall bit rate : 1 097 kb/s
Writing application : Lavf51.12.1
Video
Format : AVC
Format profile : Baseline@L1.3
Format settings : 1 Ref Frames
Format settings, CABAC : No
Format settings, RefFrames : 1 frame
Format settings, GOP : M=1, N=12
Codec ID : H264
Bit rate : 1 090 kb/s
Width : 480 pixels
Height : 320 pixels
Display aspect ratio : 3:2
Frame rate mode : Variable
Frame rate : 20.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.355
Stream size : 2.12 MiB (99%) -
I would try using VirtualDub2 with its included x264 8-bit encoder. Make frame size and frame rate the same as your sample. Then adjust the encoder settings to Profile:Baseline, Level:1.3.
https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Profiles
https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC#Levels
See if that works. If not, you may need to set individual encoder settings like the GOP size (keyframe interval), number of b-frames, etc.
Add subtile (srt) file to existing mkv file
By Hansen in forum SubtitleReplies: 6Last Post: 4th Dec 2016, 03:58 -
Best Video Convert To Avi With Accurate Target File Size
By TheRandomOne in forum Video ConversionReplies: 2Last Post: 11th Aug 2016, 12:44 -
Help: Trying to replicate .mp4 encode settings from existing files (Mac)
By U2Joshua in forum Newbie / General discussionsReplies: 2Last Post: 29th Mar 2016, 08:42 -
MKV to AVI - File size doubles
By denniscool in forum Video ConversionReplies: 17Last Post: 25th Apr 2015, 02:13 -
What are the best settings for reducing avi file size (VirtualDub) ?
By Editall in forum Newbie / General discussionsReplies: 14Last Post: 24th Feb 2015, 12:02
