Hello, This is my first posting something on this forum.
Long story short, How do i download videos from v.qq?
Not the premium ones. I'm talking about the free ones which doesn't require any sign-in.
Please help. I searched everywhere but didn't find any ways.
You guys are my last hope.
Hope This Helps~
Results 1 to 13 of 13
He gave an example of a v.qq video that IDM was able to download, and the output result that IDM produced.
He did this because you said IDM "doesn't grab a sh*t".
He gave an example of a case where IDM did "grab a sh*t" of a v.qq video.
He couldn't do it for whatever v.qq video that you are interested in, because you didn't provide any such example link. -
I see. Will give it try. Thanks for clarifying.
When i try to download a video from YT, why does it grab in all formats? For example, I only want it in 1080p, but it will all format from 260p to 1080p.
I had to stop all downloads and again select the 1080p. It's a little bothersome. Is there any way to stop it?
Plus how many sites does it support?
Any list? -
Different people have different preferences - someone may decide to use 360p resolution.
You may use command line argument "-res", its usage is described in bottom of FAQ page.For example, I only want it in 1080p, but it will all format from 260p to 1080p.
Also you may disable option "Detect all resolutions/bitrates of video" in settings dialog to display only highest resolution/bitrate from detected videos.
Disable option "Start downloads automatically" in settings dialog and then all detected downloads will be 'Idle' and require further manual start (double click or from popup menu). When required download is started - pressing 'Ctrl+I' (or navigation button broom) will clear all inactive downloads (Idle, Done).I had to stop all downloads and again select the 1080p. It's a little bothersome. Is there any way to stop it?
Short answer: mostly all. Middle answer: there is no internal database of supported sites - media streams are detected by sniffing network traffic.Plus how many sites does it support? Any list?Last edited by TubeDigger; 4th Nov 2018 at 09:11.
How to rip videos from videoland.com
By robza171 in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Mar 2018, 13:20 -
How can I rip videos from this particular website?
By aruwin in forum Video Streaming DownloadingReplies: 20Last Post: 27th Dec 2015, 04:09 -
How to rip from tenplay videos ?
By Joshua20 in forum Newbie / General discussionsReplies: 0Last Post: 18th Sep 2015, 13:47 -
Is it possible to rip hardsubs from youtube videos?
By aruwin in forum SubtitleReplies: 5Last Post: 1st Jul 2015, 14:53 -
Can't rip DVD home videos to PC
By ashleyl725 in forum DVD RippingReplies: 12Last Post: 18th Nov 2013, 07:53
