Hello friends.
Does anyone know how to create "batch" to fix subtitles within videos in mkv?
For example: I uploaded an anime with subtitle softsub with 12 GiB in size. Now I need to fix a minor error in the subtitle and add the translation of the song, but I did not want the guys to need to download the video again because it's too big.
Thank you for your time.
You can use XDELTA Asssuming you have your orig and new (edited) file you can scan and create a patch file ...
https://sourceforge.net/projects/xdelta3-gui/
If only changes to text part like chapters, subs, the delta file will be smallLast edited by teodz1984; 3rd Nov 2018 at 23:21.
If you didnt dave the original you have nothing to compare it with the edited one...
Probably the most pragmatic solution is just send the softsubs to whoever needs it. -
[QUOTE=teodz1984;2533104]If you didnt dave the original you have nothing to compare it with the edited one...
I have everything necessary.
It all worked out, thanks to his tip. The real problem now is to replace the file in torrent, since it depends on the administrators.
Thanks for all the help
Just include a lnk to the delta patch you created ... no need meddle with file replacement
Subtitles in a black box to cover up existing embedded subtitles.
By Leg_end in forum SubtitleReplies: 4Last Post: 7th Dec 2016, 00:23 -
Someone know how to fix 3-lines credit-style subtitles? (.srt)
By flatzonmavoz in forum SubtitleReplies: 7Last Post: 15th Nov 2016, 16:32 -
How to fix 3-lines credit-style subtitles (.srt)
By zaerdy in forum SubtitleReplies: 1Last Post: 14th Nov 2016, 23:15 -
How can I fix this?
By gil900 in forum AudioReplies: 0Last Post: 18th Dec 2015, 11:29 -
Converting HD-DVD subtitles To BLURAY subtitles
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 7th Sep 2014, 06:15
