  1. I have installed AviSynth, downloaded AVSPmod, and tried to open AviSynth script file permanently as AVS source file with AVSPmod script, but it doesn't change to default. This must happen in order to use AviSynth. Can somebody help me with this? The other pc have no problems with that.
  2. Originally Posted by jseo13579 View Post
    Did you mean set the file association ? It's not "required" to run avisynth - it's more of a convenience thing. You could chose to have it open with vdub2 by default, or notepad, for example
    Right click any .avs file => properties => where it says "opens with" there should be a "change" button. Then you can set whatever default application you want
  3. I am PLEABS
    Apr 2018
    Earth
    if you mean file association try on AVSPmod
    Option > Associate .avs file with AvsP
  4. I did, but the AviSynth does not work on one of my pc. I did it exactly the same way for my other one, but it worked just fine. Coding doesn't recognise.
  5. Never mind. Solved the problem.
