Try DVDFab and copy Ultra HD Blu-rays and DVDs! Or rip iTunes movies and music! Download free trial !
    Oct 2018
    Hi all, so I need a software which will turn pre-rendered frames (86) into a video but keep the transparency so I can overlay the video onto another.
    The images(frames) are PNG and I dont have a preference for the video format used.
    Which software will allow me to do this?
    I don't have a budget so please tell me the best one.
    Thanks,
  2. Originally Posted by kully00000 View Post
    Thanks,
    You should have a preference, because you would want a format that is compatible with whatever you're using to perform the overlay.
    That will determine what your options are
    So what are you using ?
    Do you even need to do this ? For example, most video editors can import image sequences
  3. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Do you want an overlay video that is entirely semi transparent or a video that has certain backgrounds that are completely transparent?
    Aug 2010
    San Francisco, California
    Very simple with FFmpeg. Your filenames should contain a sequential number to indicate ordering of the frames. Then,
    ffmpeg -i myimage%d.png -c:v huffyuv myvideo.avi
    will produce a losslessly compressed video with alpha channel. %d is a placeholder for the number in the filename.
