I don't know if it on here but I am putting it here. I was trying to find a program that could do multiple video files and convert to MKV video files. I figured out how do to it with MKVToolnix.
To convert multiple files to MKV files using MKVToolNix do the following.
Start MKVToolNix
Click on Multiplexer
Drag the video files you want to convert to MKV into the Multiplexer.
Then create a job output file by clicking on the Output button at the top of screen then click the add to job queue button at the bottom right of the screen. Then click OK, your first file should be added to the job queue.
Then remove the file from the top of the screen by clicking on the red x. It should have the next file with the X red. So just add to the job queue.
Then continue to do the same for all the remaining files.
You can view the files to be converted by going to the Job Queue and then when in that area go to the top of the screen and select Start All Pending Jobs.
After all the files are converted you can either quit the program or if you have more files you need to convert then go into the Job queue area and remove the ones that are completed.
Hi,
for me easiest way to do this is -> drag all files to mkvtoolnix icon, have it setup to open each file in different tab. Then go to menu Multiplexor, Action for all tabs, Start multiplexing... Done
Edit: + removing files from job queue can be done automaticaly when finished without problems
BernixLast edited by Bernix; 28th Oct 2018 at 17:11. Reason: Edit
Not 'Latest News'. Moving to 'Newbie/General Forum.
Moderator redwudz -
(1) Go to "mkvtoolnix GUI" in the top menu, then Preferences (or Ctrl+p), Multiplexer, and at the "Adding Files" drop-menus select "Always ask user" for all three options. Then save the changes.
(2) When you add/drop a bunch of files into the "Source files" section of the "Input" tab of the Multiplexer, a window with options will appear; there you select "Create new multiplex settings for each file", and wait while all the files load.
(3) When all the jobs (layers) have been created, go to Multiplexer on the top menu, then "Actions for all tabs" and select "Start multiplexing". Wait for the jobs to finish.Last edited by barmah; 7th Sep 2022 at 21:14.
@barmah
Thankyou!
I'm processing a bunch of files with too many sub streams and this fits the bill.
Converting MKV and AVI video files into regular DVD without watermark/logo
By peripatein in forum Authoring (DVD)Replies: 8Last Post: 16th Jan 2019, 18:45 -
Issing re-joining mkv files split using mkvtoolnix
By Odaik in forum Video ConversionReplies: 47Last Post: 31st Mar 2017, 16:25 -
Cant merge mkv video and audio with mkvtoolnix?? any ideas?
By kjy in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2016, 12:37 -
Help with batch converting MP4 to MKV with MKVToolnix
By Joe Schmoe in forum Video ConversionReplies: 1Last Post: 11th Jun 2015, 13:53 -
Video Newbie needs ultra basic help...please! Converting mkv files.
By six-h in forum DVD RippingReplies: 6Last Post: 19th Aug 2014, 18:54
