I can't find any program to just straight capture/transfer mini dv to a mac properly. Each has issues (and some editing apps don't have Capture at all like Lightworks and DaVinci Resolve). I've tried iMovie 9.0.9, iMovie (latest version), Media 100, Avid Media Composer (which wouldn't even install on my machine for whatever reason), Premiere Pro (current and CS6), LifeFlix, Vidi, , Video Pad, Quicktime, all sorts of things. LifeFlix and Vidi have come the closest so far, but both of them have the same glitch:
When I capture a tape that has a mini edited video with music on it, that part of the tape gets messed up audio. In the case of LifeFlix, the messed up audio continues for a bit even after that part of the tape is over. This is with multiple tapes in multiple cameras, and the tapes play perfectly fine in the cameras.
I just want a program I can use to capture all of my tapes as a single file per tape (many programs create a new file for each time you press record on the camera). I know LifeFlix lets you Combine All clips, but that's where I'm getting those glitches too.
Oh wise people of the forum......any ideas?
sounds like whoever made the tape didn't use the same audio format throughout. it probably alternates between 32 and 48 bit audio. the camera won't care but capture programs do. you will have to capture each part where the audio changes individually, starting and stopping at each change so the program sets the proper bit rate as they can't change it on the fly.
Issues With Capturing From Mini DV Camcorder
By escobar45 in forum Capturing and VCRReplies: 6Last Post: 24th Aug 2019, 19:54 -
cTivo to Mac mini
By allne-uk in forum MacReplies: 6Last Post: 6th Jul 2017, 11:21 -
Sony Z1 mini-DV tape to Final Cut Pro on mac: which camcorder?
By FayeD1977 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Mar 2017, 10:39 -
Trouble converting from Mini DV to iMac iMovie (loss issues at times)
By TKHanson in forum Video ConversionReplies: 1Last Post: 18th Dec 2016, 11:47 -
Help! HI8 to Mac transfer through Mini DV
By sketchypremise in forum Capturing and VCRReplies: 5Last Post: 20th May 2014, 11:18
