Hi.
When I open mts file (from Sony camcorder) I get some issues:
- first 24 frames are missing (frame 25 is first frame in VD2 - video is "shifted" to left by 24 frames)
- last 24 frames are copy of last frame
Number of total frames are correct.
Any help? Or workaround?
Hi, mts files support is currently poor. You may read them with help of avisynth or vapoursynth and ffms2 source plugin.
If you provide a sample I will check what is the problem.
VirtualDub2: Force Keyframe every x frames
By ConvertKonvert in forum Newbie / General discussionsReplies: 10Last Post: 24th Sep 2018, 09:15 -
Opening MTS with virtualdub doesn't go smooth
By Bencuri in forum Video ConversionReplies: 7Last Post: 31st Aug 2018, 18:56 -
Green line around Virtualdub2 window
By Gotanno in forum EditingReplies: 9Last Post: 2nd Jun 2018, 14:56 -
Using ffmpeg to extract frames from mts file fails
By Prototype v1.0 in forum Video ConversionReplies: 30Last Post: 1st May 2015, 00:39 -
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 21:21
