I am using a USB LIVE 2 Hauppauge bought from Dell (not knockoff) to record old vhs tapes. Funny thing is when I record items from professionally recorded tapes (flight instructions, tutorials, old lesser known videos, etc) it works perfectly. But then I try recording off of tapes my dad recorded off live tv, it basically only will display / record the commercials. As soon as a show comes on it freezes or blanks out. The only thing I can think of is it's either blocking poor quality (which doesn't seem to be the case as other worse videos record) or security / anti-piracy.
That doesn't really make sense either but it's so weird. It will actually stop at the very end of a commercial... Like right when it fades out. Like it will get stuck in the vcr's blue screen with PLAY osd shown until a commercial.
Any ideas? Are there other softwares that work with the USB LIVE 2?
THANK YOU!
Quite possible that the broadcaster switched on some anti-copy device and the Hauppauge detects the change in the signal.
It might help if you could indicate the original broadcaster to give people familiar with its workings some more info to work with. -
The network is UPN (Paramount). If true, I had no idea that was even possible for over the air analog TV! Do you know of that is for realz?
I downloaded dscaler but got a bit worried about their BSOD/ hardware damage comments. I may give it a try on a old laptop! Thanks for that suggestion!
I forgot to mention that I'm running Windows 10.
Thank you both! -
I also use an OLD version of Magix Movie Edit to capture, along with the usual WinTV that came with the unit.
Video/Audio sync problems with Hauppauge USB-Live2 & Vdub
By liddle in forum Capturing and VCRReplies: 34Last Post: 30th Dec 2025, 08:15 -
Elgato Video Capture vs. Hauppauge 610 USB-Live 2 - Raw Comparison
By CZbwoi in forum Capturing and VCRReplies: 40Last Post: 6th Dec 2022, 14:40 -
Copying recorded video files from a Philips DVDR3570H to a USB unit
By tribeca in forum DVD & Blu-ray RecordersReplies: 9Last Post: 26th Jan 2016, 19:44 -
Hauppauge HD PVR 2 video freezes in capture software
By Yankee_In_TX in forum Capturing and VCRReplies: 3Last Post: 18th Oct 2014, 21:22 -
Need >$500 camcorder that outputs live video through Firewire/USB
By btrotter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 5th Nov 2013, 09:22
' returns.
