Okay, so I've got a particular problem I need to solve.
I'm authoring a Blu-ray and there is a part of the video where a song starts playing in the background while characters continue to speak in the foreground. Both the lyrics to the song and the dialog is in Chinese.
I have a translation for both the dialog and the lyrics to the song. I want to display subtitles for both, in different styles, even though they overlap somewhat.
What I'm envisioning is subtitles for the dialog with a black outline while the subtitles for the lyrics have a blue outline. When the lyrics for the song start, the dialog subs will display above them, timed to the dialog that is spoken. While the subtitles for the lyrics will display below, correctly timed to the song being sung in the background.
I'm using Aegisub to create different Styles, saving it as an .ASS file, then creating a Blu-ray compatible SUP file with easySUP. I'm also familiar with Subtitle Workshop and Subtitle Edit.
This should work correctly, but when I burn a disc, the subs that overlap don't display correctly. They flash on and off extremely quickly and a couple don't show at all. The subs that don't overlap play perfectly.
Is there a way to achieve what I'm looking for? I'm pretty sure I've seen this same thing on commercial Blu-rays, I'm just not sure how to make it work with the tools I generally use.
Thanks.
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Results 1 to 1 of 1
Overlapping Subs
By Armstrong69 in forum SubtitleReplies: 4Last Post: 20th May 2018, 00:50 -
Command-line method for correcting overlapping display times? vtt to srt.
By nobodyhome in forum SubtitleReplies: 2Last Post: 15th Mar 2017, 17:36 -
Weird SD 4:3 and 16:9 Clip - How to display it properly via Avisynth?
By VideoFanatic in forum RestorationReplies: 42Last Post: 6th Jan 2015, 12:20 -
Overlapping two videos
By miscguy in forum EditingReplies: 5Last Post: 21st Nov 2014, 07:08 -
How do I remove overlapping frames from several video pieces?
By OddTheodora in forum EditingReplies: 4Last Post: 4th Feb 2014, 11:37
