hello guys,
I recorded a HD stream which has a very strange resolution of 1904x1072. I want to convert it to a BD compatible format. I'm using avisynth and x264 for that purpose.
I read that Spline64Resize is the best resizer and better than for example Lanczosresize.
I wonder if it's enough to just use "Spline64Resize(1920,1080) " or if I have to use "AddBorders(?,?,?,?)" as well so that the right 1.78 aspect ratio is kept intact
I'm pretty bad at mathematics so I would appreciate your help.
regards
-Gwar
1904x1072 is almost 16:9, however 1904x1071 is exactly 16:9.
(1904 / 1071) = (16 / 9) or 1.77777778
You can use the Avisynth resizers to crop a single pixel when resizing. To crop a single pixel from the bottom to reduce the height to 1071 before resizing to 1920x1080:
Spline36Resize(1920,1080,0,0,0,-1)
I use Spline36 for just about everything. Spline64 would be fine. You'd probably need bionic eyes to see a difference for such a small amount upscaling.
By the way, if the source has square pixels, the resizing formula is pretty simple.
Original Height / Original width * New Width = New Height
1072 / 1904 * 1920 = 1081.0084
So even if you resized directly to 1920x1080 it'd only be "off" by a pixel. Not enough to notice any distortion. However....
1071 / 1904 * 1920 = 1080Last edited by hello_hello; 25th Oct 2018 at 13:09.
Every resizing has the potential to screw up the picture by creating/accentuating moire artifacts, creating oversharpening halos or blurring the picture. I wouldn't bother with resizing or worrying about the aspect ratio (unless it's way off, say, a 2.35:1 video anamorphically squeezed in a 1904x1072 frame). Just add black borders. Nobody will notice unless watching on a TV with a white bezel.
thanks a lot guys. @Manono: Could you please explain how you get the 8,4,8,4 borders for the 1904x1072 resolution ? I want to understand how you calculate it. I understand that the 8 is probably to add 8 to 1072 to get a 1080. But I don't get what the 4's mean
thanksLast edited by Gwar; 25th Oct 2018 at 15:11.
1920 - 1904 = 16 --> 16 / 2 = 8 pixels left and right
1080 - 1072 = 8 --> 8 / 2 = 4 pixels top and bottom
from 4:3 to 16:9, in crop/resize mode and avisynth 64 bit?
By marcorocchini in forum Newbie / General discussionsReplies: 27Last Post: 25th Oct 2017, 22:45 -
avisynth: what is the internal faster resize algorithm?
By marcorocchini in forum Newbie / General discussionsReplies: 6Last Post: 3rd Oct 2017, 12:11 -
how to tell to AVISYNTH: adjust resolution if not 1920x1080?
By marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2016, 12:54 -
Best Resize And Sharpen Filters In Avisynth
By anime12345 in forum Video ConversionReplies: 4Last Post: 24th Sep 2015, 09:55 -
avisynth: when I resize where is the interlaced flag?
By marcorocchini in forum Newbie / General discussionsReplies: 28Last Post: 24th Sep 2014, 05:55
