Hi,
I know it's being asked many times, I also searched and found something free, but I need the most Pro one with highest possible quality!
So it should be commercial rather than free right? What are the best ones you know?!
Cheers![]()
Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Drive Director Optical Media Burn Solution :: www.omidsoft.com/download-drv.html
If its already comlaint and dont need a menu use tsmuxer. If you want a menu try multiavchd. There's others but I haven't personally used them much
if all else fails read the manual -
Have you tried DVDFab Bluray Creator, professional Blu-ray creator and burner software that can burn all sorts of videos into Buray.
Hi DVDFab Staff,
I tried your software in a profession video studio of my friend!
However, it didn't work for embedding UTF-8 sub titles which is vital for us.
After contacting your support, I've been told that it's currently NOT supported and no any estimated date for when & if it will becomes available?!
So, still looking for something like DVDFab but with UTF-8 support for sub titles...Drive Director Optical Media Burn Solution :: www.omidsoft.com/download-drv.html -
blu-disc studio lite is what i use to author blurays. try the free lite version first and see if it handles what you need, if not you may have to purchase a paid version.
I use TMPGEnc Authoring Works 6 for my dvd/blu-ray authoring projects.It supports srt utf-8 subtitles.
Thanks very much, excellent application
Bluray from mkv
By fazza8 in forum Newbie / General discussionsReplies: 7Last Post: 9th Feb 2018, 17:51 -
Bluray Mkv to normal bluray disc
By Igniz in forum Video ConversionReplies: 3Last Post: 10th May 2017, 23:15 -
Sony BDP S1500 bluray player does not play .MKV file or burned bluray DVD
By theguy22 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2015, 18:10 -
Create Bluray (MKV->Bluray) with custom menu
By ThaDraGun in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Aug 2015, 20:52 -
Making BluRay from MKV?
By knightmire in forum Authoring (Blu-ray)Replies: 18Last Post: 7th Jan 2014, 02:07
