Try StreamFab All-in-One and rip streaming video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
    Oct 2018
    Hi all. Sorry 1st post here so not sure where it goes. I have had a look through the hacks and trying to find one for the above player. This is the UK version (dunno if that makes a difference). I have tried various things but cannot get the DVD region free. Im not fussed about region free blu ray.
    All the posts I have seen say about using a One For All remote...however I was wondering if I can use the sideview app or something similar (android app) to put the code in as I dont want to have to buy another remote (One For All). I have the small controller with no numbers on it (attached). Any help would be gratefully received
    Image Attached Images
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Just copy your "foreign" DVDs to MKV files with your computer, put those MKV files onto a portable hard drive, plug that portable hard drive into your Sony player and watch them that way.
