I may be answering my own question here, in that from what I have read, it is only possible to save an .avi clip, that has unwanted sections removed, in Full Proccessing Mode in VirtualDub. However, I would prefer the .avi file to be saved as original as I seem to remember, possibly incorrectly, that previously, I was able to do this in Direct Stream Copy. Currently, I have ensured that the cuts were on(k) frames but when attempting to Save As .avi, I am notified " Unable to open file for write ......:The process cannot access the file because it is being used by another process ", whatever that is, as I have no other processes open. I am however, able to Save as Old Format .avi, which is not ideal.
Any thoughts, suggestions or recommendations would be much appreciated.
I'm using the newer Virtualdub2.
Open the file specifically as 'avi' (not 'all types') and select 'Direct Stream Copy' and only cut on K frames before saving.
Alternatively, instead of Direct Stream Copy select 'Smart Rendering' and cut on any frames, then under Compression choose the same codec as the source (probably XviD MPEG-4).
Only the cut points are encoded - the rest of the frames are saved without re-rendering. -
It depends on what codec is used inside the AVI container. For DV AVI files, Direct Stream Copy lets you save "cuts only" edits without any re-encoding.
Are you trying to overwrite the original file? This can't work. You should save to new file. -
Thanks very much everyone for the infomation and advice, which I have followed, and has resolved the issue.
VirtualDub -> Batch saving image sequence won't work properly
By killeriguana in forum EditingReplies: 8Last Post: 24th Sep 2018, 12:48 -
Jitter when Saving simple AVI from VirtualDub
By prezzacc in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2018, 17:46 -
using virtualdub to batch process deshaking, saving using h264 codec
By seanincali in forum EditingReplies: 7Last Post: 31st Mar 2017, 11:38 -
Problem with merging AVI files using VirtualDub
By rocknrolla115 in forum EditingReplies: 2Last Post: 9th Apr 2016, 17:19 -
Saving a video as an mp4 with VirtualDub?
By Bruce Wayne in forum EditingReplies: 6Last Post: 2nd Jun 2015, 18:43
