I didn't recommend that because the timing of a for loop will vary with CPU speed. That's especially problematic if you need to call it thousands of times (long enough for the next frame to be decoded). But if you're lucky, a small number of queries may be enough to trigger the decoding of the next frame.
Results 151 to 152 of 152
Maybe there is something about Windows 10 that is incompatible with what I'm trying to do.
I'm going to get the Linux version of PureBasic and see if I have any luck on Lubuntu (lite Ubuntu) running on a virtual machine.
I've tried many workarounds and experiments and I just can't get this program to function properly.
I know nothing about graphics/GUI programming in C and even less about the dreaded C++.
There is also Lazarus which is Pascal-like.
Help Converting YUV to RGB
By chris319 in forum Video ConversionReplies: 7Last Post: 24th Sep 2018, 18:51 -
RGB to YUV to RGB
By chris319 in forum ProgrammingReplies: 70Last Post: 20th Feb 2017, 16:49 -
ffmpeg/x264 RGB to YUV
By SameSelf in forum Video ConversionReplies: 40Last Post: 14th Nov 2016, 18:40 -
YUV/ RGB problem in Avisynth
By spiritt in forum Newbie / General discussionsReplies: 9Last Post: 6th Sep 2015, 04:31 -
is this YUV or RGB?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 20th Apr 2014, 10:21
