Hi there,
Can you guys post where did you buy your DVD-R (DVD-RW) discs. How much you paid. And how's the quality? (I mean, what speed you burned, what's the model of your DVD-R(W) drive and did all your DVD-ROM drive can read them?)
I think if we can collect this kind of information, we can help others by choosing the correct store to buy correct DVD-R(W) which are not so expensive.
Here's my "no good" result....DVD-Rs from cd-recordable.com
My drive is DVR-104.
First try:
I bought some blank DVD-Rs from cd-recordable.com for $59 (25 DVD-R).
I can see clearly there's "uneven dye coating" on EVERY DVD-R. But I still tried to burn them at 2X and 1X. The results are the same: can be burned.....but when I read back the data to compare, it looks like it has difficulty in reading back.
And when I put in a DVD-ROM drive and try to read back and compare with original data, it always stuck. It looks like it has difficulty to read it.
Second try:
I got another "no brand" DVD-R. Burned with 2X. Same sympton as the above. And I get another disc and try at 1X. It's better, at least the DVD-R drive can read back the data and compare OK. (the option with NERO 5.5.78). But when I put that DVD-R in my laptop's DVD-ROM, nothing can be read.
I will keep trying and post my results.
Check out my thread:
http://forum.vcdhelp.com/viewtopic.php?t=88018
This is exactly the topic we are trying to cover.
Hi, guys, i need help with my picture dvd...thanks!
By Lady Colour in forum Authoring (DVD)Replies: 11Last Post: 22nd Dec 2010, 11:46 -
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 02:34 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
How do you guys transfer vhs movies to dvd?
By mmmipa in forum Newbie / General discussionsReplies: 5Last Post: 15th Mar 2008, 17:34
