  1. Trying to get DeHalo-alpha to work with StaxRip. I've downloaded the avsi file and put it into the Plugins folder of StaxRip, but it says "not a valid Win32 application". The code I'm using is
    LoadPlugin("J:\StaxRip-x64-1.7.0.0-stable\Apps\Plugins\Dehalo_alpha_MT2.avsi")
    Am I doing it completely wrong?
  2. You loaded the AVSI, but never actually used it in your script. In addition, do you have the other necessary filters needed to make it work?
    Note the example of its use shown at the bottom of the Dehalo_Alpha page.
  3. LoadPlugin is for dll files, not AVSI scripts. You want to Import() rather than LoadPlugin(). Then, as manono said, you need to call the function. Importing it only makes it available. Something like dehalo_alpha(rx=6.0, ry=1.0). The values should be set to values appropriate for your video. There are many other options available too. See the docs.
  4. Originally Posted by jagabo View Post
    Thanks, that worked
  5. Originally Posted by jagabo View Post
    Darn, now why didn't I catch that? I use the Import command in every script I create. Thanks for the correction.
