Hi guys,
is it possible transform a simple sbs 1080p24 to a normal Blu-ray format?
This because nearly all Projector handle only sbs 1080 50i or 60i.
I think better transport to Blu-ray format than to interlaced.
Yes, it is possible. And if it's already 1080p24, that means it is only a horizontal stretch, stream split, re-encode & reauthor, vs. additional framerate change and other things.
However, maybe not where you live, but in many places you can get projectors that support other forms of 3D. Depends on cost, model, brand,...
Note that you should re-encode using MVC codec format, and (re-)author to BD3D for your attempt to work properly & automatically. That means something like Vegas Pro+DVDApro, or Cyberlink Power Director Ultimate, at minimum, etc.
But interlaced isn't that bad in a pinch, even for 3D.
Leawo Blu-ray Player: Problems Playing Blu-Ray Discs
By devilcoelhodog in forum Software PlayingReplies: 11Last Post: 24th Mar 2017, 08:32 -
Should a Region 2 DVD played on a multi-region Blu-Ray player look normal?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Mar 2017, 10:46 -
author 3d blu-ray from sbs video?
By YorkieOl in forum Authoring (Blu-ray)Replies: 9Last Post: 16th Jun 2016, 22:35 -
LG blu-ray player is stopping playing blu-ray discs
By mausinho in forum DVD & Blu-ray PlayersReplies: 2Last Post: 22nd Feb 2016, 09:55 -
pioneer blu ray burner -want to make 1:1 copies of my blu ray movies
By Cool joe in forum MacReplies: 10Last Post: 10th Dec 2014, 22:31
