I insert the tape and it does not seem to detect that I have inserted a tape. It makes no attempt to spool the tape around the drum.
If I keep ejecting and loading the tape sometimes it will eventually detect it and load the tape around the head and then it functions normally. It takes several tries.
VHS-C Camcorder
There should be an IR LED/photodiode assembly that goes "inside" the tape when it's loaded that tells the camcorder that there's a tape inside. The photodiode might not be picking up the reflected light.
Sections of tape won't play on JVC VCRs
By Username in forum Capturing and VCRReplies: 7Last Post: 16th Sep 2018, 02:40 -
AvsP Won't load the video
By TsUNaMy WaVe in forum EditingReplies: 4Last Post: 23rd Aug 2015, 02:22 -
SVCD2DVD won't load asset files
By Alex J. in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Dec 2014, 07:16 -
RemoveDirtMC won't load
By Elegant in forum RestorationReplies: 4Last Post: 21st Jul 2014, 11:00 -
Avchd won't load files
By mou353 in forum Authoring (Blu-ray)Replies: 16Last Post: 28th Feb 2014, 22:39
