is there anyway we can set min bitrate for CRF mode? in CRF mode dark scene looks really bad. so i want to set min bitrate to make the dark scene better.
Not directly ; but you can influence a certain minimum quality indirectly
You can set a hard limit on qpmax, but it's probably not what you want - it can negatively impact other sections, especially simple sections like titles etc.. will be overdistributed
You can play with aq modes (mode 3 places bias to dark scenes specifically) and aq strengths, qcomp - but that will usually increase bitrate everywhere , not just dark scenes. ie. Filesize will usually be much larger than what it has to be.
Or you can either specify zones manually, such as a bitrate multipler over specific sections. That is probably the most effective, but the most work, because you have to identify ranges -
identify the dark film frame ranges and apply crf by zones.. eg (in x264)
--zones 21140,21380,crf=15/55973,59840,crf=15/79880,80267,crf=15責任者-MDX -
thanks for reply, i used qpmax 27, looks better now
Difference between Very slow and fast preset in CRF mode
By iKron in forum Video ConversionReplies: 4Last Post: 9th Sep 2018, 05:39 -
Encode suggestion - CRF and 2pass-BR
By vidblue in forum DVD RippingReplies: 6Last Post: 16th Feb 2017, 06:35 -
How to reduce file size in CRF mode?
By ben45 in forum Video ConversionReplies: 10Last Post: 24th Aug 2016, 16:47 -
DVDFab 9 CRF, Handbrake/Vidcoder x264 CRF
By hogger129 in forum Video ConversionReplies: 10Last Post: 30th Dec 2015, 10:51 -
FFMPEG: how to encode in target size mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 19th Mar 2015, 14:03
