Hi all,
I have a much loved and care worn Sony HVR - A1P camera. I would love to modernise but funds won't allow right now. This camera came out many years ago, and the memory stick it came with is a 32MB (!) Memory Stick Duo Magic Gate. As such I am still using mini DV video cassettes, but I'm working with Final Cut 10 now and I've noticed it doesn't like tape very much. Does anyone know whether the newer Memory Stick Duo's retained the same dimensions as the old ones? Or whether there is an adapter that fits in a Memory Stick Duo slot but holds a smaller card?
Many thanks,
Peebs
You are out of luck, there is no adapter or update you could do to the camera.
If you still want to work with it get an older computer with Windows XP or Linux to capture the tape.
How to play the recording of a Sony Bravia TV on a usb stick?
By cypherinfo in forum Video ConversionReplies: 12Last Post: 11th Jan 2021, 16:49 -
Fix: TV or player not recognizing USB memory stick
By Doogy2Shox in forum DVD & Blu-ray PlayersReplies: 6Last Post: 30th May 2017, 13:47 -
Would like suggestions for USB memory stick data recovery
By jimdagys in forum ComputerReplies: 4Last Post: 6th Jan 2016, 21:19 -
USB Memory Stick Not Showing Text Files
By Teac23 in forum ComputerReplies: 4Last Post: 9th Jun 2015, 13:16 -
General question about USB memory stick that corrupted files
By jimdagys in forum ComputerReplies: 5Last Post: 29th Nov 2013, 17:22
