Hi !
I am in the process of organizing footage for a web series and the editor is asking me to organized the footage into scenes bins for every episode.
This should be simple if there wasn't external audio to sync beforehand. I would only have to selects the clips for each scenes and drag it in their respective folders.
But as I am synching audio manually on a timeline for each day of shooting, I find myself unsure of what to do next.
I know that you can merged each clips and rename it like you wanted and then drag it in the approprate bins. But, I read that it's a very bad thing to do if you intend to send it to a audio mixer because it erases all metadata and you can't export OMFs or AAF properly.
I was thinking of doing a sequence for a scene. Like a sequence named Scene 01 and in it : every takes of scene one in chronologically order.
And then drag this sequence in the episode bins.
But the only problem I see with it is that the editor will not be able to do match frame with the external audio sync to it...
Is there a better way to do all of it ?
I've heard about multisequences, but I don't know if it's the appropriate way to go since I don't have more than one camera.
(Sorry for my english )
Results 1 to 1 of 1
Best External TBC or Frame Sync for Betamax tapes
By Deter in forum RestorationReplies: 5Last Post: 6th Nov 2017, 13:32 -
Premiere Pro CC 2015 - "Step Forward 1 Frame" doesn't jump to next frame
By xyron in forum EditingReplies: 1Last Post: 30th Nov 2016, 10:05 -
Frame by frame editing - Premiere Pro, Sony Vegas, or ???
By Zoltan Losonc in forum EditingReplies: 60Last Post: 19th Aug 2016, 16:30 -
the clip doesn't match the sequence help , premiere cc 2015
By rama in forum EditingReplies: 7Last Post: 3rd Apr 2016, 19:41 -
may i know when should i use match sequence in premiere cc?
By rama in forum EditingReplies: 7Last Post: 19th Nov 2014, 11:36
