Results 1 to 14 of 14
    Oct 2018
    Thailand
    Hi guys, I have some annoying problem with MeGUI.
    I try to encode my karaoke subtitle to my anime with tags blur and fade-in and fade-out, {\blur2\fad(500,800)}, aegisub can display this effect
    But when I try to encoding this subtitle, I found a problem, MeGUI don't display effect.
    How can I fix it?
    Thank you and sorry for my English
    Aug 2013
    Central Germany
    MeGUI only offers one subtitle plugin for AviSynth: VSFilter. But there are several more which may have a better support for a specific subset of ASS features.
    Who knows, maybe MeGUI will offer a selection of subtitle filters in the future ... I asked the developer.
    P.S.: Your English is fine.
  3. Are you using the same fonts for the kanji? Are they installed? Upload ass file (only relevant lines/styles). What MeGUI revision? What is your OS?
    Oct 2018
    Thailand
    I installed kanji fonts for sure and I try to show you the tag effect “blur” and “fad” it work when I open in aegisub but it doesn’t work when I encoding my vdo. My MeGUI is version 2112, windows 8.
    P.S.: Sry, I just shut down my pc. I will upload ASS file after that.
    Oct 2018
    Thailand
    This is my ASS file
  6. I don't have DF極太丸ゴシック体 font to test. With Arial I don't see any difference.
    [Attachment 46957 - Click to enlarge]
    P.S.: Why is your vsfilter.dll path "MeGUI\vsfilter.dll" and not "MeGUI\tools\avisynth_plugin\vsfilter.dll"?
    Oct 2018
    Thailand
    Coz my MeGUI is old version and "MeGUI\vsfilter.dll" it's work before I upgrade my os from windows 7 to windows 8
    This is all of fonts in my pc
    https://drive.google.com/open?id=1gmZTKNxWxNZPA7kuzAlNHadgRmox0Juh
  8. The font seems to be there (MRGC_1.TTC). Maybe it's a problem with your old MeGUI version (no one wants to support old versions). Latest MeGUI uses vsfilter.dll from here.
    [Attachment 46959 - Click to enlarge]
    Oct 2018
    Thailand
    Ok, Thx for your help. I will try a new version of MeGUI ^^
    Oct 2018
    Thailand
    After I try a latest MeGUI. It's work!!! Thx again
  11. Originally Posted by momomeepooh View Post
    I try to encode my karaoke subtitle to my anime with tags blur and fade-in and fade-out, {\blur2\fad(500,800)}, aegisub can display this effect FetLife IMVU Canva
    How can I fix it?
  12. Originally Posted by sneaker View Post
    お前もうしんでいるのか?
    どこかで聞いたことがあるさ。あの七つの傷の男ケンシロウだよね。
    北斗の拳
    Try this Ruby or Furigana effect, it gives a fancy look to your subtitles.
    https://www.youtube.com/watch?v=57FYtnF5JEk
  13. Originally Posted by momomeepooh View Post
    How can I fix it?
    This is possible with MeGUI you just need installed same fonts that you are used in lines.
    And for any help about aegisub effects feel free to contact me.[emoji846]
    Sent from my LG-M700 using Tapatalk
