AA=ffmpeg.exe version N-85093-g7942907 built with gcc 4.9.4 = 58.2 Mbytes in size
BB=ffmpeg.exe version n3.1.2 built with gcc 5.4.0 = 56.0 Mbytes in size
since BB= has a higher GCC number, I am using BB= even though it is smaller in size
and I found no difference in functionality between AA= and BB= past 2 years. they seemed the same.
and AA= and BB= work under XP.
what would the today's XP supporting ffmpeg.exe be?
what ffmpeg.exe would you recommand for win10?
sometimes when you recommanded so and so XP supporting ffmpeg.exe's they didnt work well. they are picky
AnonymousGuest
It depends on who builds those XP-compatible releases.
Just as an example, I've just found this page with the help from the false god Gluegow:
https://opensourcepack.blogspot.com/2017/12/ffmpeg-for-windows-xp.html
There exists a thread dedicated to XP-friendly ffmpeg binaries @ Zeranoe's forums, but I don't know how "up-to-date" it is.Last edited by Marsia Mariner; 15th Oct 2018 at 05:05. Reason: grammar
ffmpeg-20181015-c27c7b4-win64-static\bin\ffmpeg.exe
ffmpeg-20181015-c27c7b4-win64-static\presets\
has
ffprobe.xsd
libvpx-1080p.ffpreset
libvpx-1080p50_60.ffpreset
libvpx-360p.ffpreset
libvpx-720p.ffpreset
libvpx-720p50_60.ffpreset
why does ffmpeg.exe have the same directory level as presets? I dont understand "presets" are not even in a branch level.
so is it ok then to delete all xxxx.ffpreset files? so that I could move ffmpeg.exe to a parent directory and run it like an old way. -
I've been using "ffmpeg-N-90853-g3914a76-win32-static_legacy.7z" on XP for a while. I thought I downloaded it from here, but it's not listed. I think those versions are XP compatible, but don't hold me to that. I vaguely remember they were complied without something I wanted, but if so, I can't remember what it was.
I found the version I'm using here.
It's dated 2018-04-26 so it's not that old, but there's also a more recent version dated 2018-08-26. I haven't tested that one yet, but "legacy" in the file name suggests continued XP compatibility.
Edit:
I took the newer version out for a quick test drive on XP. So far, so good.
(Referring to "ffmpeg-N-91691-g962c931-win32-static_legacy.7z" here).Last edited by hello_hello; 15th Oct 2018 at 09:49.
ffmpeg.exe -i %1 -r 1 xxx-%06d.JPG what is better quality capture command?
By sommers in forum Newbie / General discussionsReplies: 4Last Post: 5th Jun 2017, 13:06 -
ffmpeg.exe keeps crashing
By Randomletters in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 17th Jan 2017, 15:04 -
ffmpeg.exe has stoped working
By downer in forum SVCD2DVD & VOB2MPGReplies: 33Last Post: 6th Aug 2014, 17:45 -
ffmpeg.exe encoding mjpg at the highest quality possibile
By marcorocchini in forum Newbie / General discussionsReplies: 10Last Post: 18th Nov 2013, 16:28 -
ffmpeg.exe encoding in VFW as MEncoder?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 11th Nov 2013, 15:47
