  1. best graphic card for video rendering/editing under 1000$
    nvidia nvenc
  2. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    GTX 1050 has the same encoder as the 1080 ti I believe.
    Aug 2006
    I did a little research. A GTX 1080 Ti has two NVENC engines so, it would potentially be faster than a GTX 1050 Ti under some conditions. See this thread in another forum: https://devtalk.nvidia.com/default/topic/987460/nvdec-cuda-nvenc-speed-comparison/
  4. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Have to wonder why Nvidia would do that unless a single chip can't do 4k60.
  5. Member Bernix's Avatar
    Apr 2016
    Europe
    Hi,
    i had 1050ti and tested 4min 57s mins long video. Then i purchased 1070ti. Tested same video. Both has same chip but 1070ti was about 5% faster. Probably because 4GB vd 8GB but don't believe much in this, also there is difference big in cuda cores, but they shouldn't be included. So there is some faster encodings in higher GPU class. But why, don't know. Used just encoding to Nvenc HEVC, no filters no audio.
    Actual difference was 4m 46s vs 4m 32s
    Bernix
  6. thanks all for reply
    i have now gtx 1060 ,its awesome , but i wonder if gtx1080ti or 2080 can reduce render time / and how much difference it make like that
  7. Member hydra3333's Avatar
    Oct 2009
    Australia
    Originally Posted by gta5 View Post
    i have now gtx 1060
    not the 3Gb version I hope, apparently it is a crippled construct (less cores !!??!!) than the 6Gb version.
  8. i have 6gb 1060
    and just found out that its software optimization not the hardware
    means if you have 2080ti it wont get you best untill the software is optimise,and also 2080 series is expensive,even 1080
