I'm trying to move from Pot Player to MPC-BE, however, I am having an audio issue after installing LAV filters and madVR. I originally had these two filters installed for Pot Player, but it was crashing a lot so I am moving to MPC-BE. Now I get this audio issues with both Pot Player and MPC-BE, I will hear background noises of the audio track, but not voices. If I stop the movie and restart it that fixes the audio most of the time, but when I pause the video and hit play again the problem comes back. If I use bitstreaming on LAV audio it seems to fix the problem, but then I can't control the volume through windows which is not really a solution. I even tried disabling LAV audio filters to see if that was the issue, but that doesn't seem to fix it either. Any ideas?
My setup is Windows 10, MPC-BE 64bit with LAV and madVR, going from HDMI to a Yamaha receiver 5.1 setup.
EDIT: I've noticed when I change the speaker setup in windows from 5.1 to 7.1 or from 7.1 to 5.1, that seems to be a temporary fix, but I have to keep changing it back and forth.
Do you have a center channel speaker? If not, make sure the speaker setup isn't set to use one -- the center channel will be going nowhere and that's where most of the dialog is.
How to Detect an 2nd audio voice which plays for few sec in bkground of vid
By prithvi in forum AudioReplies: 7Last Post: 20th Sep 2017, 10:52 -
1080p > 720p without losing audio sync
By pstnn in forum Video ConversionReplies: 3Last Post: 18th Sep 2017, 23:48 -
Media Player Classic / MPC-BE / MPC-HC : differences between them
By devilcoelhodog in forum Software PlayingReplies: 19Last Post: 25th Jun 2017, 18:54 -
Suggestions for some voice changing software for cartoon voice-overs?
By dilophosaurus65 in forum AudioReplies: 0Last Post: 15th Mar 2017, 17:03 -
extracting dubbed voice from a audio
By Tri P in forum AudioReplies: 7Last Post: 11th Nov 2014, 12:44
