Hi. First time poster so apologies if this has been asked before.
I have been left a lot of super 8 fine film and would like to digitise them. To get it done professionally would cost a couple of thousand pounds so I have been looking at purchasing a frame by frame scanner.
My question is, which scanner will give the best finial result.
• The reflecta super 8+ (https://reflecta.de/en/products/detail/~id.853/reflecta-Super-8-and-Scanner.html)
or
• The wolverine moviemaker pro (https://www.wolverinedata.com/products/MovieMaker_Pro)
Any information and advice would be really appreciated
There are several threads in the forums about film (8mm or super 8) scanners.
For the Reflecta you can read a quite long topic at:
https://forum.videohelp.com/threads/366069-The-Reflecta-Super8-film-scanner-to-avi-con...light=reflecta
Or there is the Hammacher scanner at:
https://forum.videohelp.com/threads/382653-Super-8-film-scanner-from-Hammacher-Schlemm...light=reflecta
Or the Somikon at:
https://forum.videohelp.com/threads/388575-Capturing-Super8-with-Somikon-Filmscanner-p...light=reflecta
All, or most, of these work the same way and scan a single frame and compile a mp4 video from these.
But there are other ways. to 'capture' film. I have had quite reasonable results from a Kaiser 'Mirror Box' that takes s projected film in one side and use a video camera in the other.
There will be many topics on here about methods. The 'capture' sub-forum may well not be the best place to look since as far as the forum is concerned this is technically not capturing
Anyone know a super super fast free mkv to mp4 ripper (non re-encoding?
By Goshite in forum Newbie / General discussionsReplies: 6Last Post: 8th Jul 2017, 13:33 -
Super 8 in 2016
By SameSelf in forum Latest Video NewsReplies: 32Last Post: 1st Mar 2016, 11:06 -
Super 8 ---> 4K or higher?
By Super8-4K in forum Video ConversionReplies: 2Last Post: 12th Mar 2015, 17:17 -
Some more Super Spam
By poisondeathray in forum Off topicReplies: 1Last Post: 5th Dec 2014, 05:38 -
SUPER Encoder... please help
By Chiggy in forum Video ConversionReplies: 12Last Post: 23rd Mar 2014, 13:52
