I have a 768mb mpeg4 that the run length is 2 hours and 10 minutes. I load the video on the program following the guide. I select to create as a iso for dvd-5.
I see at bottom the bar is green,no red, but it's like 4850/4850, can't remember the exact size from memory and I'm not home at the moment. I start converting and everything goes fine.
When it's done I play the video in vlc player and it only converted half the movie. Like a hour 35 of it and then it stopped even though it said it was done.
I have also tried using convertxtodvd. I find it easier to use, but for some reason. Every iso I play in vlc player plays fine, but when I use imgburn to burn to disc, the audio is always off by about 2 seconds. I've made so many coasters. I can't figure out why the audio is off after burning.
Oh I thought by auto selecting dvd-5 the program would automatically set the correct bit rate to fit
This program create a very good log, have a look, the problem may be right there.
The log usually ends up in the same folder as the DVD output -
ConvertXToDVD vs AVStoDVD
By djdelarosa25 in forum Video ConversionReplies: 7Last Post: 28th Jun 2017, 08:14 -
Need to create thumbnail chapters on DVD creating with AVStoDVD
By Studly in forum Authoring (DVD)Replies: 10Last Post: 10th Dec 2015, 11:06 -
Did AVStoDVD get rid of ImgBurn?
By gastrof in forum Newbie / General discussionsReplies: 6Last Post: 4th Mar 2015, 00:54 -
Authoring DVD as .iso With AVStoDVD
By Altern881 in forum Authoring (DVD)Replies: 3Last Post: 27th Apr 2014, 23:09 -
AVStoDVD; no .iso
By agent222 in forum Authoring (DVD)Replies: 4Last Post: 13th Dec 2013, 08:25
