Results 1 to 17 of 17
    Feb 2018
    europe
    hello,
    I'm working on a video , for personnal use only, and the vide has some burnt subtitles. So I decided to use the Skier's AVS script from https://forum.videohelp.com/threads/358181-How-to-remove-hard-coded-subtitles-HELP-PLE...SE#post2481785
    For that script, it works perfectly, The result is quite good. Look at this my script for harcoded subtitles :
    LoadVirtualdubplugin("C:\Users\**\Desktop\Nouveau dossier (2)\plugins32\exorcist.vdf", "Exorcist", 1)
    LoadVirtualdubplugin("C:\Users\**\Desktop\Nouveau dossier (2)\plugins32\Bright.vdf", "Brightness_Contrast", 1)
    SubtitleTopLeftX = 298
    SubtitleTopLeftY = 790
    SubtitleTopRightX =1620
    SubtitleTopRightY = 790
    clip = DirectShowSource("F:\****.mkv").ConvertToRGB32()
    maskclip = Levels(clip, 113, 10.000, 255, 75, 210)
    maskclip = GeneralConvolution(maskclip, 0, "
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10 ", 256, false)
    clip2 = OverLay(clip,maskclip,0,0,mode="subtract")
    clip2 = Blur(clip2, 1.58)
    clip2 = ConvertToYUY2(clip2)
    clip2= Tweak(clip2, hue=25.7,bright=32,cont=7.0)
    maskclip = Crop(clip2, SubtitleTopLeftX,SubtitleTopLeftY,-SubtitleTopLeftX,80).ConvertToRGB32.crop(0,0,0,-2).Trim(0,0)
    maskclip = maskclip.Brightness_Contrast(-254, 32)
    maskclip = ConvertToYUY2(maskclip)
    maskclip = Tweak(maskclip, hue=-180.0,sat=0.0,bright=22,cont=10.0)
    maskclip = ConvertToRGB32(maskclip)
    maskclip = maskclip.Levels(0, 0.281, 100, 6, 177)
    maskclip = maskclip.Greyscale()
    maskclip = maskclip.Exorcist(2, 100)
    maskclip = maskclip.Exorcist(-2, 100)
    maskclip = maskclip.Brightness_Contrast(-21, 32)
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25 ", 256, false)
    maskclip = maskclip.Core(116,0)
    maskclip = maskclip.Blur(1.58)
    clip = dekafka(clip, maskclip, SubtitleTopLeftX, SubtitleTopLeftY, maskclip.width, maskclip.height,216)
    clip = ConvertToYV12(clip)
    return clip
    Then I want to insert an image, at X frame of the video. so my script for this is :
    DirectShowSource("F:\***.mkv").ConvertToRGB32()
    logo = ImageSource("C:\Users\***\Desktop\test2.png").Conv ertToRGB32()
    logooverlay = Overlay(logo, x=0, y= 0, mode="blend")
    Trim(0,4312) ++ logooverlay.Trim(4313,4424) ++ Trim(4425,150626)
    on these 4 lines, my script works perfectly
    But when I decide to put it on my previous long script (the harcoded subtitles script), the script for adding image seems to not working. I dont have avisynt error, but the image don't appear on the screen
    Could someone have some idea please ? Why I can't "join" 2 scripts like this ?
    Is it possible ? if yes, how ?
    thanks a lot.
  2. The Return line at the end of the first script is the end of it. Anything following it would be ignored.
    From near the end of your first script, try something like this. I'm assuming both scripts refer to the same DirectShowSource video? If so, it's probably easier to keep "Clip" assigned only to the source video.
    Here, the output of the first script becomes NewClip1 and the image is overlayed on that as NewClip2, rather than overlaying it on an unprocessed version of the DirectShowSource video. I assume that's what you're wanting to do?
    NewClip1 = dekafka(Clip, maskclip, SubtitleTopLeftX, SubtitleTopLeftY, maskclip.width, maskclip.height,216)
    # skip the ConvertToYV12 and Return lines at the end of the first script
    # skip the DirectShowSource line at the beginning of the second script.
    Logo = ImageSource("C:\Users\***\Desktop\test2.png")
    NewClip2 = Overlay(NewClip1, Logo, x=0, y= 0, mode="blend")
    # Change NewClip1 to Clip in the line above, if you want to overlay the image on an unprocessed version of the source video.
    NewClip1.Trim(0,4312) ++ NewClip2.Trim(4313,4424) ++ NewClip1.Trim(4425,150626)
    ConvertToYV12()
    Feb 2018
    europe
    hello
    thanks for answers, so now it works perfectly
    however, I need some other help, always in this script.
    I would if possible to blur hardcoded subtitles only between frame number 4740 and frame number 132834.
    I tried to put
    .Trim(4740, 132834)
    after this line
    but it doesn't work : the mask seems to be "copied" only between 4740 and 132834 frames
    how could I just blur my hardocded subtitles only between 4740 and 132834 frames ? where do I must put my Trim script ?
    thanks so much
  4. Remember the original clip then use ReplaceFramesSimple(original, nosubs, mappings="[4740 132834]").
    Feb 2018
    europe
    hello, thanks
    I've tried, even with replacing original and deleting nosubs, but, I've got some error for this line
    in the avisynth wiki they said
    ReplaceFramesSimple(baseClip, sourceClip, mappings="[10 20] 25 30")
    in my first clip (of first message here) what are my baseClip and my sourceClip ?
    In fact, now, my entire script is for the full length of my video. I don't want to remap or replace frame, I just want my script ONLY between 4340 and 132834 frames, not the full video
    do you see what I mean ?
  6. RemapFramesSimple replaces frames in the first clip with the specified frames from the second clip.
    Feb 2018
    europe
    I understand what RemapFramesSimple do, but I've got only ONE video, not two.
    And when I try your script, all my entire script for removing hardcoded subtitless is "cancelled" : I see again all hardcoded subtitles
    do you help me with the good syntax please ?
  8. Originally Posted by sulkiyan View Post
    Did you read my first post?
    Then you'll have two clips for ReplaceFramesSimple().
    Feb 2018
    europe
    yes I saw it
    this is what i added at the end of my entire script
    clip = DirectShowSource("F:\***.mkv").ConvertToRGB32()
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\RemapFrames.dll")
    ReplaceFramesSimple(clip, maskclip, mappings="[4740 132834]")
    I tried all possible things for replaceframessimple (sourceclip and baseclip), and at each time, it's not working
  10. sourcelclip and baseclip are symbolic names in the examples. Replace them with the names of the clips in your script.
    I don't have some of the filters you're using, or a suitable test clip, so I can't test this -- but I think it will work:
    original = DirectShowSource("F:\****.mkv")
    clip = ConvertToRGB32(original)
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    # at this point "original" is the original video, "clip" is the video with subs removed
    ReplaceFramesSimple(original, clip, mappings="[4740 132834]")
    logo = ImageSource("C:\Users\***\Desktop\test2.png").ConvertToRGB32()
    You shouldn't use DirectshowSource(). It's not frame accurate. Use a frame accurate source filter like LSMASH or ffms2.
    Feb 2018
    europe
    thanks, after modifications, I don't have error, but the script for removing the subs is ALWAYS applied for the ENTIRE video, not for video part between 4740 and 132834 frames.
    it's strange
  12. I haven't used ReplaceFrames, and I'm still not 100% sure what you're wanting to do, but I assume for the script below "Clip" is the source video, "Clippy" would be a second source video if you're using one (otherwise you don't need that line), "NewClip1" is the clip with blurred subtitles, and "NewClip2" is the clip with the overlayed image. You can overlay the image on "Clip", "Clippy" or "NewClip1", whichever you specify for Overlay(), and it'll be "NewClip2".
    Clip = DirectShowSource("F:\****.mkv").ConvertToRGB32()
    Clippy = DirectShowSource("F:\****.mkv").ConvertToRGB32() # if the clip for overlaying the image is different to the previous one
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    NewClip2 = Overlay(Clippy, Logo, x=0, y= 0, mode="blend") # specify Clip, Clippy or NewClip1 as the video to overlay the image, whichever you want to use.
    Clip.Trim(0,4312)\
    ++ NewClip2.Trim(4313,4424)\
    ++ Clip.Trim(4425, 4739)\
    ++ NewClip1.Trim(4740, 132834)
    ConvertToYV12()
    Then it should just be a matter of changing the trims to append the frames from the appropriate clips. This is the same as appending them on a single line, but it's easier to read.
    Clip.Trim(0,4312)\
    ConvertToYV12()
    I can't test it either, but that should work.
  13. Originally Posted by sulkiyan View Post
    Post your entire script.
    Feb 2018
    europe
    here my entire script
    original = DirectShowSource("F:\***.mkv")
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    logo = ImageSource("C:\Users\**\Desktop\test2.png")
    NewClip2 = Overlay(clip, logo, x=0, y= 0, mode="blend")
    clip.Trim(0,4312) ++ NewClip2.Trim(4313,4424) ++ clip.Trim(4425,150626)
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\assrender.dll")
    AssRender("C:\Users\*\Desktop\A.ass")
    AssRender("C:\Users\*\Desktop\C.ass")
    AssRender("C:\Users\*\Desktop\D.ass")
  15. Whenever you don't specify a clip by name the name "last" is used automatically. In your script ReplaceFramesSimple is creating a clip called last. Which is then ignored by the rest of the script which is using "clip" instead. Changing the line to "clip = ReplaceFramesSimple..." should take care of that problem. Then there are some useless lines near the end of the script.
    Try this:
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    10 10 10 10 10
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    25 25 25 25 25
    clip = ReplaceFramesSimple(original, clip, mappings="[4740 132834]")
    Feb 2018
    europe
    No, it won't be necessary to copy th script just above.
    I take the one on your previous post and I added ++ Clip.Trim(132935, 150626)
    (you've forgot it :P and my video was cut at 132934 frame.
    so now, everything is working perfectly
    thanks so so much for your suggestions , appreciate
    PS : before I go, I'm wondering if with some avs script I could put a logo following end credits ? OR do I make it with premiere pro ?
    If you don't know, doesn't matter,
    thanks so so much, see ya
  17. Just create a blank clip with the same properties as your video and overlay your logo, then append it at the end.
