This line works good (good means: attitude as we expected)
But, when you change codec to libx265 — nothing works. Well, something IS hidden but not all as in the sample above. –loglevel 0 doesn't work too. Next lines are simply matchless.Code:ffmpeg -i "in file name" codec=-c:v libx264 -preset fastest -c:a aac "out file name" -v quiet -stats
By the way, outputting stderr and then to file makes lib265 totally quiet! But, communication with user is invisible too (Replace file Y/N for example) and I’d like to keep that visible (as the execution line with counter which is present in libx264.Code:x265 [info]: HEVC encoder version 2.8+74-fd517ae68f93 x265 [info]: build info [Windows][GCC 8.2.1][64 bit] 8bit+10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX x265 [info]: Main profile, Level-4.1 (Main tier) x265 [info]: Thread pool created using 4 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 2 / wpp(17 rows) x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 2 inter / 2 intra x265 [info]: ME / range / subpel / merge : star / 57 / 3 / 3 x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 30 / 8 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 1 x265 [info]: References / ref-limit cu / depth : 4 / on / off x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : CRF-28.0 / 0.60 x265 [info]: tools: rect amp limit-modes rd=6 psy-rd=2.00 rdoq=2 psy-rdoq=1.00 x265 [info]: tools: rskip limit-tu=4 signhide tmvp b-intra x265 [info]: tools: strong-intra-smoothing lslices=4 deblock sao
Any help highly appreciated.
He he... yep! You are the King!!!
My code
1. loglevel 0 sucksCode:stringVariable=-c:v libx265 -preset slower -x265-params log-level=-1 -v quiet -stats -c:a aac ffmpeg -i "In file name.ext" %stringVariable% "out file name.ext"
2. log-level=-1 :: g-l is essential!
Any order dependable issues in stringVariable in you opinion?
[del]Any link about that log-level=-1?[/del]
https://trac.ffmpeg.org/wiki/Encode/H.265
https://x265.readthedocs.io/en/default/
Thanks thanks thanks!!!
is libX265 encoder in latest FFMPEG is the same as standalone x265 encoder?
By junglemike in forum Video ConversionReplies: 5Last Post: 21st Sep 2016, 01:36 -
Where to download ffmpeg that support libx265 10 bit
By innosia in forum Video ConversionReplies: 2Last Post: 26th Jun 2016, 15:06 -
ffmpeg does not apply parameters with libx265
By z-machine95 in forum Video ConversionReplies: 15Last Post: 19th Aug 2015, 04:29 -
ffmpeg do not apply parameters with libx265
By z-machine95 in forum Video ConversionReplies: 1Last Post: 28th Jun 2015, 16:57 -
2pass encoding (ffmpeg libx265)
By z-machine95 in forum Video ConversionReplies: 18Last Post: 3rd May 2015, 01:43
