How do I change the subtitle color of an mkv video on a Mac?
Start by telling the format of the subtitles and what program is used for playing the video.
I'm not a MAC user so I'm afraid the only way I can think of is somewhat cumbersome.
If you don't already have it install MKVToolnix. Assuming your video has a video-, audio- and subtitle track extract the idx/vobsub with
Code:mkvextract tracks color.mkv 2:test.srt
[Attachment 46916 - Click to enlarge]
Else you need to edit the color palette
[Attachment 46917 - Click to enlarge]
This may involve some trial and error. The color palette has 16 entries of which 4 is used in the subtitle: BG Background (often transparent), TXT (which I ussume is the one you want to change), OUT outline often black, ANT antialiasing often grey if used.
[Attachment 46918 - Click to enlarge]
Unfortunately there are no rules for how these colors are mapped to the palette but it is most often the first 4 entries.
If you have access to a Windows PC you could use BDSup2Sub++ to visually edit the colors in the idx/vobsub.
After editing mux the video with the new idx/vobsub using MKVToolnix GUI.
How to change a single subtitle image in a PGS subtitle file??
By Gregostus in forum SubtitleReplies: 8Last Post: 14th Nov 2017, 01:26 -
SubRip font color change
By hibbs in forum SubtitleReplies: 3Last Post: 1st Jun 2016, 19:44 -
Subtitles Change Color
By lomaidala in forum SubtitleReplies: 5Last Post: 18th Jan 2016, 16:09 -
How can I change position, color and encoding UTF-8 in subtitle Quicktime?
By Jamaika in forum Software PlayingReplies: 0Last Post: 29th Sep 2015, 01:53 -
Color change after encode
By Tylerr in forum Video ConversionReplies: 8Last Post: 7th Jan 2015, 07:31
