Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or try DVDFab Passkey and copy Blu-ray and DVDs! :)
  1. Hello,
    I am trying to convert several files (VTS_01_1 to VTS_01_4) extracted from a DVD to a single MP4 file.
    I used Handbrake to convert the files and MS Photos to merge.
    The problem is that when I convert one of the original files, some kind of a menu or an overlay appears, as seen here:
    [Attachment 46896 - Click to enlarge]
    It is not visible in the original VTS_01_2 file. Could be something related to other VTS files which include menu...? I really do not know.
    Is there any way of removing it?
  2. You don't convert the individual vob files on their own rather the whole dvd!
    If you have decrypted the dvd to hdd and want to use HandBrake in order to reduce filesize then use "Open source -> Folder (Batch scan) and select the folder VIDEO_TS"
    If filesize is of no importance and you want to preserve quality (and being fast) then use MakeMKV (which also acts as a decrypter) then use ffmpeg to re-mux to mp4
    ffmpeg -i mkvfile.mkv -codec copy mp4file.mp4
    assuming that the audio codec from the dvd (AC3) can be used on your target device.
  3. How do I convert the whole DVD? A friend gave me the files - VIDEO_RM folder, VIDEO_TS.BUP, VIDEO_TS, VIDEO_TS, VTS_01_0.BUP, VTS_01_0, VTS_01_1, VTS_01_2, VTS_01_3, VTS_01_4 etc.
    I picked VTS_01_1 to VTS_01_4 and converted those, ignoring the rest of the files. I guess that it is not a correct procedure.
    I do not have the DVD physically, just those files. I am not sure whether they comprise the full image of the original DVD.
  4. You're missing the file extention. But I guess VIDEO_TS, VIDEO_TS could be VIDEO_TS.IFO, VIDEO_TS.VOB and you have a complete structure. Try the "Open source -> Folder (Batch scan) and select the folder VIDEO_TS""Open source -> Folder (Batch scan) and select the folder VIDEO_RM" in HandBrake.
  5. I did that and it says the input is invalid. I guess a file or more files is missing.
    So if I have a separate video_ts_01_2 file on its own (which plays flawlessly in vlc player) how do I convert it to mp4? Other recommended software (other than Handbrake)?
    The rest of the files are ok, only one of them has that "black frame" overlay.
  6. Drag the file VTS_01_1.VOB onto MKVToolnix. The other VOB files are automatically added. Press "Start Multiplexing" and test the resulting MKV file in VLC and if there's no menu overlay use that file as source for conversion to MP4.
