  1. devdev devdev's Avatar
    Sep 2003
    hi
    im trying to capture a pal video 8 tape with final cut express
    im capturing ok but at end it's saying that my captured audio sample rate does not match the sample rate on the source tape
    but cannot find where i change the 'capture preset' settings
    any ideas welcolme please
    Oct 2018
    Scotland
    Check your tape players audio settings then you can check audio settings in Easy Setup. Verify they match.
  3. devdev devdev's Avatar
    Sep 2003
    my camcorder is a digital 8 pal dcr-trv110e pal by the way
    my current setting in easy setup is pal dv-pal dv converter - thats the only setting which allows me to capture at all (other pal setting simply say waiting for timecode) unless i'm missing something
    Oct 2018
    Scotland
    you need to go into the dcr-trv110e's menu settings (VTR / Camera button) and find Audio Mode and change it from default of 12 bit to 16 bit. You cannot select AUDIO MODE for tapes recorded in the Digital8 system. You, however, can select AUDIO MODE when you dub tapes recorded in the Hi8/standard 8 system to another VCR using the i.LINK cable.
    here's the manual:
    https://www.sony.co.uk/electronics/support/res/manuals/3865/38659711M.pdf
  5. devdev devdev's Avatar
    Sep 2003
    hi bar 72 i've gone for option 1 and it seems to have nailed it!!
    that's really appreciated
    nb - my capture setting is dv-pal dv converter (which is set for 48khz) does whether it's 32 or 48 matter then since i imagined that older tapes like video 8 this would have to be 32 but as i said - it seems to be capturing fine at 48khz
    Oct 2018
    Scotland
    nice one! enjoy
