Hi all!
I would like to know how should the ffmpeg command line order look like to achieve what the filter "Limiter" does in Audacity (Soft Limit).
If it exists, it would be best if the filter applied only to the center channel (in a 5.1 audio file)
This is a screenshot of Audacity of what I want to apply:
Thank you
See alimiter filter documentation, you will need to combine that filter with channelsplit and amerge filter, so you can apply it to single channel only and than merge all channels back.
FFMpeg : Use the "volume" filter for Preamp Equalizer setting ?
By alexander121 in forum AudioReplies: 0Last Post: 25th Jul 2015, 08:38 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
"Cue file" equivalent for playlist control
By robertazimmerman in forum Media Center PC / MediaCentersReplies: 3Last Post: 7th Nov 2014, 15:47 -
Time Stretch VIDEO, like "Change Tempo" in Audacity - Software? H
By djmoon in forum EditingReplies: 14Last Post: 18th Nov 2013, 15:47 -
the "-intra" command in ffmpeg.exe affects encoding "-vcodec copy" mode?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 23rd Oct 2013, 16:53
