Hi there,
I have this NTSC which is blended from a PAL source. After using qtgmc and srestore, the video seems quite OK except for the fact that it is "wobbly" in the sense that there are top and bottom black lines that dance back and forth (and they are not there in the source). Maybe this issue has a name but I don't know it.
How can I get rid of that nasty wobbling? I tried changing bobbers, just in case (yadif instead of qtgmc), but to no avail.
Here are two samples (the "vanilla" one has no processing). Thank you!
Results 1 to 17 of 17
Try cropping away the top/bottom black borders, before or after QTGMC:
Code:LWLibavVideoSource("wobble vanilla.mkv") QTGMC() SRestore(frate=25) Crop(0,2,-0,-2) #AddBorders(0,2,0,2) # optional -
First of all, sorry, I didn't explain myself correctly above: it's not just the black bars that come and go, but the whole image that wobbles.
But neither of those two options seem to work for me, even though jagabo's NoWobble file indeed has no wobble. Here's my current script:
MPEG2Source("source.d2v", cpu=0)
Crop(10, 68, -0, -72) #used to be (10, 66, -0, -70)
QTGMC()
srestore()
(and a Trim command to get that snippet) and what I get, attached, still wobbles. It's easily noticeable in the letters at the beginning. What's going on? -
you should crop at the end not before qtgmc and srestore
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
If you're working with an MPEG 2 source why didn't yo upload a sample of that? Use DgIndex, mark a section, File -> Save Project and Demux video. Upload the resulting M2V file.
Sorry, I didn't know how to do that. Here's the m2v.
(P.S. I saw your AssumeTFF or AssumeBFF suggestion before the edit; didn't help) -
I get no wobble with:
Or with Crop(12,68,-8,-72) before or after QTGMC().Code:Mpeg2Source("test.demuxed.d2v", CPU2="ooooxx", Info=3) QTGMC() SRestore(frate=25)Last edited by jagabo; 10th Oct 2018 at 12:41.
All of those suggestions keep giving me the same kind of wobbliness present already in the first qtgmc file. I don't understand what's going on here.
Here's another wobbly file, gotten with the following script:
I'm at a loss here, I've no idea what's going onCode:MPEG2Source("test.demuxed.d2v", CPU2="ooooxx", Info=3) Crop(12,68,-8,-72) QTGMC() srestore(frate=25)
Yeah, that's how DGIndex is set, all right.
And indeed, it seems to be a QTGMC problem, since replacing it with yadif gives no more wobbling.
Any ideas what it might be and how to fix it?
Thanks for all your help!
EDIT: Note that I've done some rips with QTGMC in the past with the same settings and everything was OK... I just checked one of those other .avs which worked and it's still giving a nice, non-wobbly encode. -
I don't know what the problem is. All I can suggest is you try replacing each of the required plugins and the AVSI, one at a time.
Your original has a width (710) that is not divisible by four. This can cause problems. You might try cropping one pixel from either side before you do anything, thus making it 708x344.
I had to convert to uncompressed to view the video with my tools, so maybe I screwed up something, but it looks to me that the video is bottom field first. I think many PAL conversions assume top field first. You might therefore want to try putting an AssumeBFF() command in the script just after you load the video, but before you call QTGMC. -
Since I'm getting a similar problem with another file, I decided to try and to this. Sigh. QTGMC was a pain to set up.
I've a Win XP (virtual) machine. I replaced QTMGC.avsi for the latest one, 3.358s (i.e. I replace the .avsi in my plugins folder), and I get: "mdegrain1 does not have a named argument out16". I upgraded mvtools2 to the latest one, 2.7.33, and I get "Script error: there is no function named MSuper". But my mvtools2.dll is in my plugins folder, all right. -
doing this gave me smooth playback without any jumping lines with your supplied m2v sample:
MPEG2Source("C:\Users\danny\Desktop\test.demuxed.d 2v", cpu=0)
QTGMC( Preset="Slow", EZDenoise=0, NoisePreset="Slow", SourceMatch=3)
srestore(frate=25)
however if it is for some reason with the rest of your film the following also gave decent results:
tfm(order=-1, mode=5)
TDecimate(m2PA=True,maxndl=7,Mode=2,Rate=25)if all else fails read the manual -
Problem solved with some help from the AVSMeter script! Thanks to the guys at the QTGMC thread over at doom9 for the pointer.
First, the problem got solved by upgrading to AviSynth+. That got my QTGMC working faultily again (but at least something showed up).
What was causing the wobbliness was masktools. I had both a newer version and an older version, mt-masktools-26.dll, which was loading instead of the newer one. So I deleted the older and QTGMC now works like a charm. Whew.
NTSC blended from a PAL source, can't restore it properly
By bruno321 in forum RestorationReplies: 5Last Post: 6th Oct 2018, 10:42 -
PAL to NTSC with avisynth - blended frames
By nesburf in forum Video ConversionReplies: 7Last Post: 27th Dec 2017, 23:21 -
Looking for advice on what i think is blended source
By skfunnyboy in forum Video ConversionReplies: 2Last Post: 12th May 2017, 08:35 -
Laserdisc BEST source (PAL vs NTSC)
By darkbluesky in forum Capturing and VCRReplies: 35Last Post: 8th Jan 2017, 21:28 -
NTSC blended
By xuguang_he in forum RestorationReplies: 3Last Post: 16th Dec 2015, 12:46
