I run a internet radio called Phat Beats Radio Plays Rap R&B Soul Funk Reggae Chillhop Acid Jazz. I am using a program called Radioboss to run the stream for the station need help choosing what codec to stream at 96k. The program can do AAC AAC+ OGG and OPUS I am looking for a codec that will be = to 160k mp3 or better which codec do you recommend at 96k?? I am currently broadcasting at 160k AAC might be to high time to go with 96k.
Hi,
my personal favorite is OPUS, if Iam not wrong it is free and good. Therefore it is used by Discord for example. If iam not wrong. Free implementation of AAC aren't usually good as not "free"
Therefore I think OPUS is good solution.
But not audiophile not audio expert.
Bernix -
If I go with Opus will most people be able to connect to the stream even mobile devices??
Hi,
it should be problem of application you are and your listeners using. So do not expecting problems.
Bernix -
I am going with 96k AAC I could not get OPUS or OGG to work with shoutcast
https://help.shoutcast.com/hc/en-us/articles/115004705393-Recommended-bitrate-and-formatOriginally Posted by Shoutcast
Even though Opus would be best and it's free, I don't think Apple supports Opus which is dumb. I personally know of a Rock/Indie Rock station online that uses HE-AAC (AAC +), which also works on devices that only support AAC-LC (AAC). Vorbis (OGG) would also be a fine option and have always liked Vorbis but you also run into support issues with it.
Trying to get stream url for this radio station
By jimdagys in forum Video Streaming DownloadingReplies: 8Last Post: 30th Aug 2018, 10:20 -
Need help to get audio url of this radio station
By jimdagys in forum AudioReplies: 5Last Post: 12th Dec 2017, 11:05 -
From one codec to another with same bitrate, quality loss?
By MovingParts in forum AudioReplies: 11Last Post: 27th Mar 2016, 01:55 -
Want to know best way to record to HDD SiriusXm streaming internet radio
By yeoldmetalhead228 in forum AudioReplies: 2Last Post: 13th Feb 2015, 10:21 -
Trying to download archived audio from radio station
By Sakura88 in forum AudioReplies: 1Last Post: 14th Nov 2014, 08:33
